Clutch Repair job
Old Dec 19, 2006 | 01:36 PM
Defcon2030's Avatar
Default Clutch Repair job
94 Accord LX 5spd
Receipt:
"replaced new complete clutch kit
clutch, pressure plate on and throughout bearing.
also replaced clutch slave and master cylinder leaking.
clutchkit- 290.63
slave cylinder - 49.79
master cylinder - 110.75
clutch fluid - 3.60
total parts- 454.77
total labor- 450.00
<U>total cost of repairs:</U>
$937.50
did I get ripped off?
Old Dec 19, 2006 | 02:15 PM
Sly_Samba's Avatar
HTBATRACER
wow yes you did.
Old Dec 19, 2006 | 02:30 PM
technine's Avatar
Default Re: Clutch Repair job (Defcon2030)
Clutches are usually cheaper, labor is the bad part. It's a little on the high side and if he didn't need to replace master and slave cylinder he could of just did it to make some extra $$.
Old Dec 19, 2006 | 04:06 PM
iam7head's Avatar
Default Re: Clutch Repair job (technine)
are those OEM part?
i can't recall the last time the master cylinder and slave cylinder both goes back at the sametime. I am surprise he/she didn't check the clutch pedal to avoid checking what is really wrong.
Old Dec 19, 2006 | 10:07 PM
Jmumblez2001's Avatar
i have the same car defcom, if you wanna save yourself some cash and you think your mechanically inclined, do the slave and master cylinders yourself, (make sure you get OEM) and if those parts aren't OEM don't do it. You can also go to majestic honda.com and buy those parts for cheap. anyway it's your choice good luck.
Old Dec 19, 2006 | 10:12 PM
Default Re: Clutch Repair job (Jmumblez2001)
I meant to say for future reference.....DEfcom
Old Dec 21, 2006 | 11:17 AM
technine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmumblez2001 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same car defcom, if you wanna save yourself some cash and you think your mechanically inclined, do the slave and master cylinders yourself, (make sure you get OEM) and if those parts aren't OEM don't do it. You can also go to majestic honda.com and buy those parts for cheap. anyway it's your choice good luck.</TD></TR></TABLE>
I buy non OEM parts all the time and have no problem with it. I guess in some cases like headgaskets, OEM would be more of a preferable choice, but I've had no problems with NEW direct aftermarket replacement parts.
zx12ryder
Transmission & Drivetrain
Nov 2, 2010 07:04 PM
turbojohnny
Sep 22, 2006 10:35 AM
digital sol
184
Oct 30, 2005 01:49 PM
sunlei
Mar 18, 2004 08:36 PM
b20civic
Aug 5, 2002 09:09 AM
