Some oem H22A intake manifold tests
Old Dec 19, 2006 | 12:48 PM
precord96's Avatar
Default Some oem H22A intake manifold tests
First off, I have to thank Jei @ Blacktrax for the manifold and different IMS spacers.
I got to do some testing on my car over the weekend with several different combinations of OEM manifolds.
The setup:
STock JDM BlueTop H23A CH9 block
H22A head Streetmaster port by Alaniz
JUN cams, valvespring, OEM retainers
Hytech header, 3" spugen Exhaust w/ Apexi worldsport 80mm muffler
3" SRI intake w/ Bpi stack and filter
Tuned on Hondata S300 P28 (IAB's not controlled)
... I tuned each setup to about 13.2:1 AFR on 91 octane
The first was a baseline with the Blactrax stage 3 intake manifold and then I added in 2 IMS spacers made specifically for the stage 3 or 4 manifold. The IMS spacers on non-metal.
Next I swapped out the Blacktrax manifold and installed an OEM manifold. You can see the OEM beats it for the most part and the Blacktrax manifold beats it up top. My setup is fairly mild and not made to rev very high, so I figure the staged manifold is better for more radical setups.
Next I pulled the IAB plate out of the manifold and added in 1 Blactrax IMS made for the OEM manifold in place. It seemed to like this combination over the IAB.
The next test was the OEM manifold with 2 Blacktrax IMS' in place and no IAB. It didn't do as well as the single IMS.
The last test was the one I found as the winner for the day. I used 1 Blacktrax IMS and put the OEM IAB on top of it.
All of this may vary from setup to setup, depending on the different combinations of parts used. I also noticed one thing during the test, Shawn had helped to manually keep the IAB shut until about 4000 rpms and let them open and we saw a pretty good jump in power about 7-10 lb/ft in the 3-4000rpm range.
Well, I hope this helps some H series guys out there with some more options.
Old Dec 19, 2006 | 01:13 PM
Revi's Avatar
Default Re: Some oem H22A intake manifold tests (precord96)
Wow. The difference between the blacktrax and the OEM manifold is not worth it. You should of threw on a Skunk 2 Pro and see what happened.
Old Dec 19, 2006 | 02:07 PM
JDogg's Avatar
Default Re: Some oem H22A intake manifold tests (Revi)
did you try a stock manifold with NO spacer at all?? i have found this to work very well
Old Dec 19, 2006 | 02:21 PM
precord96's Avatar
Default Re: Some oem H22A intake manifold tests (JDogg)
I haven't tried pulling the IAB/IMS out completely. I will look for some bolts and try that in the near future.
Old Dec 19, 2006 | 03:37 PM
skunked's Avatar
Thanks for the info
Old Dec 19, 2006 | 04:16 PM
JDogg's Avatar
Default Re: Some oem H22A intake manifold tests (skunked)
i used some sockets as big washers so i didnt have to change the bolts
Old Dec 19, 2006 | 04:19 PM
SIXTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info
x2
Old Dec 19, 2006 | 04:47 PM
BearsEK-KMSU's Avatar
Default Re: Some oem H22A intake manifold tests (SIXTY)
great test i could tell you what the skunk manifold would have done
Old Dec 19, 2006 | 05:21 PM
SteveoBA8's Avatar
Default Re: Some oem H22A intake manifold tests (bearsEK)
Thanks for doing these tests
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by precord96 &raquo;</TD></TR><TR><TD CLASS="quote">I haven't tried pulling the IAB/IMS out completely. I will look for some bolts and try that in the near future.</TD></TR></TABLE> I want to see how this will do also.
Old Dec 20, 2006 | 10:31 PM
alphajesse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi &raquo;</TD></TR><TR><TD CLASS="quote">Wow. The difference between the blacktrax and the OEM manifold is not worth it. You should of threw on a Skunk 2 Pro and see what happened.</TD></TR></TABLE>
https://honda-tech.com/zero...age=1
^that's what happens. To save you some time, it's worth about negative twenty horsepower in the midrange and -2 horsepower on the top end. According to the thread this was also trying to tune whatever power he could with s300, and was only using a VAFC with the stock manifold.
Old Dec 21, 2006 | 01:32 AM
Pippen_001's Avatar
Default Re: Some oem H22A intake manifold tests (alphajesse)
I think the skunk2 pro IM is good with higher cr and bigger cams. Only then will you see gains.
Old Dec 21, 2006 | 04:59 AM
flyrod's Avatar
Default Re: Some oem H22A intake manifold tests (Pippen_001)
Very informative. Thanks for posting!
Old Dec 21, 2006 | 06:11 AM
b19coupe's Avatar
Nice comparison
Looks like you spent some time on it. I hope that the H-T community appreciates your hard work
Old Dec 21, 2006 | 06:29 AM
98vtec's Avatar
moderator emeritus
man, the one thing i have been looking for......dyno without the IAB plate, lol.
i have a friend who gave me a blacktrax spacer for christmas and i had been planning on a doing a dyno test between no plate at all and the spacer but wouldnt have minded if someone beat me to it. Looks like i still need to test it, lol.
cool results tho. I've always speculated about the IAB spacers. The OEM manifold with the IMS seemed to be your best result. Is that what you stuck with?
Thanks for testing this out. ME and bb4ever have been discussing proper IM sizing for the past few weeks and this is just leading me to believe that increasing size of the plenum isn't the way to go on a stock displaced h22.
Man i really wish you would have tested no iab plate, that would have saved me soooo much speculation, lol. Thanks for helping us out
BTW, you should post this in the lude section.
Old Dec 21, 2006 | 09:14 AM
ESP-net
Guest
Posts: n/a
Default Re: Some oem H22A intake manifold tests (B.Rabbit)
Good evidence to support my thinkin all of long...Honda made a good manifold for the H22A for performance...
Good info
Least your smart enough not to rip that H23 to 9k...
Old Dec 21, 2006 | 10:42 AM
UK_Luder's Avatar
Great post mate. Very interesting to see the IMS + IAB combination yielded the best results
Well done.
Old Dec 21, 2006 | 12:17 PM
The Birdman's Avatar
Default Re: Some oem H22A intake manifold tests (UK_Luder)
It's always good to see someone doing some dyno comparisons without looking to sell a certain product
Old Dec 21, 2006 | 12:23 PM
UK_Luder's Avatar
I wonder if it would make any difference on the last setup, if the IAB plate was fitted under the IMS, so the extra capacity was added to the plenum side?
Old Dec 22, 2006 | 06:54 PM
alphajesse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pippen_001 &raquo;</TD></TR><TR><TD CLASS="quote">I think the skunk2 pro IM is good with higher cr and bigger cams. Only then will you see gains.</TD></TR></TABLE>
I beleive 2point6 tested it on his really built h22 and also lost power.
Old Jan 12, 2007 | 10:11 AM
subydoored's Avatar
i read the topic and he did lose power and made most his power with the euro r
Old Jan 14, 2007 | 06:22 PM
hatch2wenty2wo's Avatar
Default Re: Some oem H22A intake manifold tests (subydoored)
Great info.
ef9_lover
Apr 23, 2013 05:54 PM
Garrett
Honda S2000
Aug 30, 2009 02:38 PM
h22prelude99
Apr 29, 2008 04:30 PM
