bad news, compression test gone wayyy wrong
actually, wasn't even able to do the compression test
so, i go to perform a compression test on the R, and when I pulled the plug wires, they gushed out oil. There is actually standing oil to a point where you can't see the plugs.
weird thing is, is that it ran and idled fine before i shut it off.
so, now what? obviously not going to drive it. does it look like a build is going down this winter?
Looks like you need to replace the O-rings that go in the valve cover! Not a problem at all, my accord did this samething, replace the o-rings and all was swell!@
I would say that just your Spark plug tubes are leaking.Remove valve cover,replace tubes and valve cover gasket.Take a shop rag and long screw driver,stick down spark plug holes to soak up any oil before you remove the spark plugs.
kroze
Jun 26, 2009 05:19 PM
95dc2teg
May 11, 2007 11:15 AM
GSX TO CX
22
Feb 3, 2005 08:10 PM
ScaleExtric
Jun 17, 2003 03:09 PM
