Will ITR koni yellow w/ ITR GC combo fit on a 97 Del Sol?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">if you get the ITR rear LCA then yes they will fit</TD></TR></TABLE>
thank you sir, would there be anything I should know about putting the these parts onto a del sol?
(thanks again)
(thanks again)
Yes...
Be very careful not to break any bolts when removing your stock rear LCAs. The bolts tend to rust solid to the inner metal sleeve of the bushings, and they won't come loose. Lots of penetrating oil & heat will certainly help. If you do break a bolt, your gonna be in a world of hurt...
Use anti-seize on all the bolts (especially the non-threaded part) when you reassemble everything.
babyS2K
24
Mar 16, 2006 12:18 PM
Del_Sol_s
Jul 22, 2005 09:24 AM
