Tachometer problem... not reading after 6500rpm
Old Dec 19, 2006 | 10:34 AM
Integra21's Avatar
Default Tachometer problem... not reading after 6500rpm
Hey everyone i have a 2.0l b18b with a gt35r and the tachometer will not read past 6500 rpms.
what would cause this? the car has a MSD blaster coil and ignition.
ive heard so far it would be an igniter problem or an ignition coil...
thoughts?
THANKS
Old Dec 19, 2006 | 10:36 AM
8YourV8's Avatar
Default Re: Tachometer problem... not reading after 6500rpm (Integra21)
damn i want your setup lol
Old Dec 19, 2006 | 11:13 AM
Integra21's Avatar
Default Re: Tachometer problem... not reading after 6500rpm (8YourV8)
haha thanks
need the tach! the car will rev to 9k on pump gas and i cant see revs past 6500!!
i cant get on her too much
HELP!
Old Dec 19, 2006 | 12:16 PM
JasonST's Avatar
I used to have a problem like this. Not entirely sure what fixed it cause I tried a bunch of things and it finally worked again. It was eather my thermostat ground was loose or the tacho signal wire was loose at one of the connectors. Does anything else unusal happen other than the tach not reading? What does the tach do does it go straight back down to zero or just stay at 6500?
Old Dec 19, 2006 | 12:49 PM
Integra21's Avatar
Default Re: Tachometer problem... not reading after 6500rpm (JasonST)
it drops down low to like 1 or 2k
there isnt any other problems per say either.
Old Dec 19, 2006 | 12:50 PM
Micha's Avatar
FAILWGN
Sorry to ask but do you have aftermarket guages?
Old Dec 19, 2006 | 03:19 PM
Integra21's Avatar
Default Re: Tachometer problem... not reading after 6500rpm (Blu99teg)
yes but its the stock LS tach/speedo etc.. -- year 2000 btw
Old Dec 26, 2006 | 05:28 PM
Integra21's Avatar
any ideas?!?!?!
Old Dec 26, 2006 | 05:53 PM
Integra21's Avatar
MSD 6AL Ignition control
MSD SS Blaster Coil
MSD Distributor cap
MSD Wires
.. is my MSD stuff.
My tuner said its prob my ignitor and the distributor may be beginning to fail.
What should i replace these with? OEM?
Old Dec 26, 2006 | 08:31 PM
JasonST's Avatar
Does it bog or cut out at 6500 rpm or does the engine keep roarin along just fine?
Old Dec 26, 2006 | 08:39 PM
Integra21's Avatar
oh it roars quite perfectly
--doesnt bog or seem to affect performance
bertsb18hatch
Apr 19, 2008 08:14 AM
sorrule
Jun 28, 2007 04:31 PM
JasonST
Aug 21, 2006 07:36 PM
ATgrills.com
Jun 22, 2005 07:50 PM
Boughetto
Aug 5, 2002 04:57 PM
