Main Studs???
Old Dec 19, 2006 | 08:23 AM
bogus_ek's Avatar
Default Main Studs???
Are these essential in a motorbuild? I did a little research and it seems as if not a lot of people include them in fresh builds. please share some opinions. Thanks
Old Dec 19, 2006 | 12:34 PM
ralph11sec's Avatar
Default Re: Main Studs??? (bogus_ek)
what will be ur setup. not really critical. oem is okay. unless ure building a super setup lolz. then it is wise to upgrade to arps.
Old Dec 19, 2006 | 04:25 PM
96Spec Ek's Avatar
Default Re: Main Studs??? (ralph12sec)
I used a set because I put a z-10 girdle in my b18b. I ordered the gsr set.
Old Dec 19, 2006 | 04:42 PM
BearsEK-KMSU's Avatar
Default Re: Main Studs??? (96Spec Ek)
If you don't plan on align honing the block its one of the worst things you could do to a block, and its an over kill 99% of the time.
Old Jan 30, 2007 | 12:47 PM
Muckman's Avatar
Moderator in Chief
Default Re: Main Studs??? (bearsEK)
Why would main studs have anything to do with align honing the block?
Old Jan 30, 2007 | 12:52 PM
DonF's Avatar
Default Re: Main Studs??? (Muckman)
Because the TQ number( compression ) is different. The same reason you re-machine the rod big end after installing ARP rod bolts.
Old Jan 30, 2007 | 02:16 PM
Muckman's Avatar
Moderator in Chief
Default Re: Main Studs??? (DonF)
Then why not just use the stock torque values?
Old Jan 30, 2007 | 02:20 PM
Jay_Sensing's Avatar
Because then they aren't at the mfg of the studs specs so the rated holding capacity is no longer accurate.
It's just one of the things involved in putting something together that will live vice putting something together that will grenade next summer.
Old Jan 30, 2007 | 02:43 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Then why not just use the stock torque values?</TD></TR></TABLE> Because ARP said not to. How is that, other than clamping force of a higher tensil strength material, which is the reason for using them anyways.
Old Jan 30, 2007 | 03:15 PM
Muckman's Avatar
Moderator in Chief
Don, in your opinion how many times can OEM main bolts be reused?
92dxbeast
Nov 10, 2011 07:27 PM
97twodoor
10
Mar 13, 2009 04:17 PM
totsie7944
Feb 20, 2008 07:27 PM
Topdawgg
Mar 14, 2007 01:35 AM
wildoutwhitegsr
18
Feb 17, 2006 07:09 AM
