Whats the name of the piece the calpier bolts to?
Old Dec 19, 2006 | 07:48 AM
crxowner's Avatar
Default Whats the name of the piece the calpier bolts to?
I was changing my brakes today (I just bought the car a month ago) its an HF crx with an LS in it so anyway I notice the brake pad that was on the car was too wide and hung over the edge of the rotor about a 1/4 inch and the caliper doesnt rotate up and down easily at allafter you remove the bottom bolt. The driver side was no problem because he used an SI hub. So I'm trying to find out the name of the piece that the caliper bolts to
Old Dec 19, 2006 | 07:49 AM
EL Vap133's Avatar
Default Re: Whats the name of the piece the calpier bolts to? (crxowner)
You mean that braket that bolts onto the knuckle?
Old Dec 19, 2006 | 07:53 AM
EL Vap133's Avatar
Old Dec 19, 2006 | 08:18 AM
crxowner's Avatar
Default Re: Whats the name of the piece the calpier bolts to? (EL Vap133)
Yea here pictures, see how the back pad isn't worn out at all
This is the piece I'm talking about
And the caliper is stuck like that and it takes all my weight to move it
ddb0825
May 7, 2017 08:13 PM
hs545
Sep 8, 2010 01:34 AM
TorquelessB16A2
Aug 14, 2008 02:14 PM
crx_in_it
May 26, 2005 03:49 PM
GroundZer0
May 15, 2003 02:49 PM
