HELP: I need measurement of the oem 99-00 Si endlink.
if anyone has one of these oem endlinks laying around, can you please measure the length of the threaded bolt section of it? i need an exact measurement. inches or millimeters.
the reason im asking is because i am doing the ASR subframe kit and oem ITR rear sway install on my ek hatch, and i have new BLOX endlinks, but it doesnt seem like the threaded part will leave much room for the nut after it goes through the sway bar. i would like to compare it to the oem endlink because this is what the asr kit comes with if you buy it as a combination (which they were sold out of) so i figured id get beefier blox endlinks.
thanx
thanx
OEM 99-00 HOOD BRA + NOSE MASK COMBO, OEM SIR LCAS , OEM SIR FRONT AND REAR SWAY BARS, OEM CAMBER KI
ek_student
Jan 4, 2009 12:08 AM
