Overheating Problem - 99 Hatch (recently Flooded)
Old Dec 18, 2006 | 10:08 PM
BlackSheep209's Avatar
Default Overheating Problem - 99 Hatch (recently Flooded)
Just needed some info and ideas on what can be the problem is.
I bought a car as a fixer. the car was flooded last year. and they said the engine is siezed. but my buddy and I got it Running. and alot of rusty water came out of the Exhaust. and blew out white smoke for awhile. But it drives fine now, and starts right up. But it overheats.
First time i notice the car overheated- the resovore tank was bubbling and look like the cap was about to bust.
Changed out the Thermostat- still same problem
And it seem like the fan doesnt turn on. Im checked the relay and fuse. but it came out fine. so Im going to change that out from my other hatch.
Any ideas? Can it be the Head Gasket?
Old Dec 18, 2006 | 10:27 PM
b18b-HB's Avatar
Default Re: Overheating Problem - 99 Hatch (BlackSheep209)
I woudl say its the head gasket... if the resovore was bubbling over...good luck
Old Dec 18, 2006 | 10:39 PM
Default Re: Overheating Problem - 99 Hatch (b18b-HB)
Thanks bro. Im gonna check the fan tomorrow. and if all fails. Im gonna get that HeadGasket Replaced.
BS209
Old Dec 18, 2006 | 10:52 PM
john666's Avatar
could always try wiring a switch to the fan and seeing if that helps ur overheating problem.. perhaps ur wiring got messed up in the flood...
Old Dec 18, 2006 | 10:55 PM
E46Kid's Avatar
If its the headgasket you will notice a milky white residue under the oil cap
Old Dec 18, 2006 | 10:57 PM
Default Re: Overheating Problem - 99 Hatch (Em1Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Kid &raquo;</TD></TR><TR><TD CLASS="quote">If its the headgasket you will notice a milky white residue under the oil cap </TD></TR></TABLE>
I will check that tomorrow when i go mess with the car. I recently changed the oil. But will the white residue still show up?
Old Dec 19, 2006 | 04:56 AM
MasterKwan's Avatar
Yeah bubbling tank is almost 100% a head gasket problem.
Old Dec 21, 2006 | 04:34 PM
Default Re: Overheating Problem - 99 Hatch (MasterKwan)
I just swapped out the Fan today. It doesnt overheat anymore.
But im getting a CEL P0505. - im gonna clean out the IACV tomorrow.
jmacc8
Honda Civic (2001 - 2005)
Aug 20, 2010 11:52 AM
Shaw14
Jul 3, 2010 12:16 AM
MFButler
Aug 12, 2009 07:40 AM
whookid007
Oct 11, 2006 07:05 PM
pushinlsteg
Oct 10, 2005 08:12 AM
