For sale Complete obd0 B16a swap hasport mounts and linkage etc. Runs excellent
I have a pre obd b16a swap for sale complete, running excellent!,
comes with hasport motor mounts, shift linkage, all coolant lines including heater core lines, fuel return line and the line from the fuel filter to fuel rail and the line from the firewall to the filter, aftermarket pacesetter header(b pipe smashed some), distributor and everything intact,throttle cable, ecu, axles, one of those tornado's that goes in your intake, brand new ngk plugs and newer oem plug wires, fuel filter and vacuum solenoid(s) still attatched, 5 speed cable transmission (grinds a little in 3rd at high rpm), clutch is pretty worn but have brand new throw out bearing pressure plate and clutch disc included, (will install for extra money) wiring harness intact also. New oil filter included. Ready to install in 88-91 civic /crx
ASKING $ 1,800 OBO SHOOT ME AN OFFER I'M OPEN FOR ANY OFFERS THANKS FOR YOUR TIME NICK 724-689-2971 Located in greensburg pennsylvania near pittsburgh. Will NOT ship pickup is a must
compression tested good (cylinder4)-195psi (cylinder 3) 200psi.
(cylinder 2) 180psi. (cylinder 1) 195psi.
after work bump wow i thought this would be gone its all ready to install shoot me some offers
143MYVTECEF
Jun 7, 2006 11:45 AM
