Simple question about replacing lights
Old May 12, 2002 | 01:54 PM
dunderpate's Avatar
Default Simple question about replacing lights
I have a 88 honda civic hatchback. The driver's side signal light has burnt out and I can't figure out for the life of me how to replace it. There's two bulbs for the headlights, but I can't see any place for the signal light. I'm sure it's something simple I've over looked (at least I hope it's simple) so anyways, If anyone knows the answer I'd appreciate it.
Thanks in advance.
Old May 12, 2002 | 02:04 PM
JDMBOLONI's Avatar
Default Re: Simple question about replacing lights (dunderpate)
there should be 2 skrews in the bumber on the ends of the lights unskrew them and take the signal light out, if your talking about the running lights then if you have a 88-89 then there will be 2 skrews on the amber part of the light, unskrew those then slide it forward, but if its a 90-91 then there will be one skrew under the hood hidden near the fender unskrew that then pull it forward, don't pull on the bulb clips they have to be turned, and they only go on one way....
Old May 12, 2002 | 03:26 PM
dunderpate's Avatar
Default Re: Simple question about replacing lights (JDMBOLONI)
Thanks mate. I assumed you had to access them from behind. Guess I just wasn't thinking.
Anyways, thanks again.
invader_zim
Mar 28, 2012 09:57 PM
CPreston
Lighting
May 21, 2009 11:35 AM
simplypinoyy
Jul 12, 2008 11:59 PM
DinDinh04
Lighting
Feb 6, 2008 03:03 PM
