:( Sadness, Selling off my K24 / frank swap parts. I'm giving up for now ... Also EF brake Parts
Old Dec 18, 2006 | 03:21 PM
bigcalidave's Avatar
Default :( Sadness, Selling off my K24 / frank swap parts. I'm giving up for now ... Also EF brake Parts
Well, It's christmas time, and the bills pile up. Unfortunately I have this motor sitting in my living room, I've failed to find a car to put it in and I'd like to get rid of everything. It's taken me a while to collect these parts and it sucks to see them go, but sometimes it has to happen.
I'd like to sell everything this week. I'm usually a powerseller on ebay, and have conducted business with many people on k20a.org, HT, etc, vouches welcome.
Payment by PAYPAL only, and I only ship to verified paypal addresses. I'll ship all the heavy stuff by fedex ground, and the smaller parts by USPS priority mail. (Or a USPS money order, and I'll ship wherever you want)
Make me an offer on these parts. I'm looking for a quick sale, but I know what these parts cost / are worth. The prices listed are what I really want
I'll post pictures later tonight, I just finally made the decision to sell all of this. Most of the parts are new, so how many times do you have to see the same pictures
Big things first
Built K20A2 Cylinder head. I bought a good condition head here, had my machine shop completely clean, surface and rebuild the head. Cams and rockers were polished. I had new valve seats cut for the SUPERTECH Stainless Steel stock size exhaust valves, and .5 mm oversized black nitrite coated intake valves. It also has Eibach EVS valve springs and stock retainers. Cams are stock K20A2, I was going to purchase some IPS cams but didn't get that far yet. $1500
Skunk2 Titanium Retainers, new in package. I bought these but they took too long to arrive and the head was already back from the machine shop so I didn't install them yet. $125
ARP Head Studs, new in box. $90
K24A1 Shortblock. This block has 4 miles on it, and is basically brand new. I'm pretty sure it was one of the trainwreck blocks. There is a little piece of webbing that broke off in shipping, it's a non critical part on the transmission side. You will see in the pictures. The piece is still there, and could be tig welded back in place if you desire. There is no oil pump / pan or timing chain (or timing cover), as I was planning on putting a type S oil pump on it. I'll include a brand new HONDA headgasket. $750
K20A3 Transmission. This one I pulled from a local wreck, (2003 civic SI) the transmission only has 30K miles on it, but in the rollover the clutch housing was cracked. There is no damage to the internal components and I bought a BRAND NEW clutch housing from honda for $250. I haven't installed it because I was going to install an LSD at the same time. The housing will be included with the transmission. It's shiny and new $750
Sorry, no picture of the entire transmission yet, it's buried in my garage and if someone REALLY needs to see it, I'll gladly get them. Here are pics of the new clutch case though!
RBC Intake manifold. 2006 Civic SI Bought BRAND NEW from Honda, and still never installed. $150
Karcepts RBC Throttle Body Plate Never Used, $75 shipped.
K20A2 Oil Pan BRAND NEW from Honda $80
Brand New Type S Shifter Box $75
Used but great condition Shifter Cable Set. I also bought brand new from honda all the clips / spacers / washers needed for installing this. $175
EP3 Engine Harness from the rollover, perfect condition. $150
EP3 CHARGE HARNESS from the rollover. cut right at the fusebox, you will probably need to extend the two wires there anyways. Rest of the harness is perfect. $65
ECU E plug, brand new. $??
EP3 Throttle Body from the rollover. Perfect condition. $180
I also have a lot of small parts, all engine sensors / valves, Vtec solenoid, etc. Ask if I'm missing something. I don't have an ECU.
Timing Side Engine Mount MAKE AN OFFER
Vtec Solenoid from the EP3, but all are the same Make an Offer
Camshaft Position Sensors Make an Offer
Crank Position Sensor Make an Offer
Oil Control Valve Make an Offer
Halfshaft from the EP3, Make an Offer!
Clutch Line Hardline on transmission, includes slave cylinder. Make an Offer
Head Water Inlet from the EP3 Make an Offer
Thermostat housing and lines from EP3 Make an offer!
ALSO AVAILABLE
EP3 Water Pump Housing / IDLER PULLEY SETUP MAKE AN OFFER!
EP3 ALTERNATOR MAKE AN OFFER
EP3 STARTER MAKE AN OFFER
EP3 EXHAUST MANIFOLD OEM MAKE AN OFFER
I also have some parts for the EF / EG civics.
BRAND NEW 1994 Acura Integra GSR Brake Master Cylinder. Great stopping power upgrade!! Never installed. $50
Brand New 11" Brake Upgrade kit for the civics. Includes new larger rotors and caliper spacing brackets. Never installed. Fastbrakes sells this kit for $250... Mine is $175
Rear Disc brake conversion for EF/EG civics. Complete. Includes rear trailing arms, brakes, e-brake cables, and energy suspension trailing arm bushings. I had these installed on my old ef civic, and they worked great. Install this entire brake setup (rear discs, front big brakes, gsr master) and your EF will stop on a dime! $250
Sorry no pics, buried with the transmission. If you really want them, I'll get you pics!
Brand New Suspension Techniques EF Civic Sway Bar kit. Missing hardware ($80 from susptech) But the whole kit costs almost $300, so get a good deal here. $125
Same thing, If you want pics just ask!
AND
2001 S2000 AP1 Instrument Cluster !!! lol, of course I have one of these. Works great!! Has the plugs too $250
S2000 Modifry ECT converter box !! Brand new, only hooked up for a few minutes to make sure they work before I recommended them to customers. $65
Pics are all over my s2000 cluster pages.
AGAIN,
All prices are OBO.
Please email me at sales@dscustoms.com and post your question here to give my post a bump
Buy yourself a great christmas present !!!
Thanks Guys!
Modified by bigcalidave at 4:22 AM 12/19/2006
Old Dec 18, 2006 | 03:25 PM
Prices are not shipped!! Shipping charges will depend on your address, but will be fair!
Old Dec 18, 2006 | 10:11 PM
BUMP
Old Dec 19, 2006 | 01:44 PM
bump?
Old Dec 19, 2006 | 01:52 PM
slogsr's Avatar
Default Re: (bigcalidave)
pmed sir
Old Dec 19, 2006 | 02:10 PM
NormanBates's Avatar
pm'd bump
Old Dec 19, 2006 | 06:41 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: (KillerAccord)
great stuff
Old Dec 20, 2006 | 02:51 PM
Anyone need the motor or head?!?! For Christmas?
Old Dec 20, 2006 | 09:18 PM
jdmek910's Avatar
pmed
dibbs on shifterbox and cables
Old Dec 20, 2006 | 10:43 PM
too late for dibs on that. Both are sold. Bumps!
Old Dec 22, 2006 | 09:20 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: :( Sadness, Selling off my K24 / frank swap parts. I'm giving up for now ... Also EF brake Parts
bump
Old Dec 24, 2006 | 11:07 AM
RDix's Avatar
nice nice...
Old Dec 27, 2006 | 01:04 PM
lilmike's Avatar
PMed
Old Dec 31, 2006 | 09:51 AM
RDix's Avatar
Default Re: (lilmike)
PM'd...
Old Jan 1, 2007 | 05:57 PM
bigfigman's Avatar
bump
Old Feb 3, 2007 | 06:04 PM
jdmek910's Avatar
pmd intested in cluster and modifry
Old Feb 6, 2007 | 06:55 PM
K-EG's Avatar
bump
Old Feb 12, 2007 | 12:56 AM
black cx's Avatar
Default Re: (K-EG)
pm'd
Colin
May 16, 2019 06:58 AM
bigcalidave
Northern California (Sales)
Jan 10, 2007 07:37 AM
92integra_gs
Dec 1, 2006 09:14 AM
