HOW CAN I INSTALL A GLASS FOR MY REAR WINDOW??????????????????????
My friend has a 1999 accord ls, and he needs to install a glass for his rear window, someone broke into her car, so i need some help installing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura »</TD></TR><TR><TD CLASS="quote">HOW CAN I INSTALL A GLASS FOR MY REAR WINDOW??????????????????????</TD></TR></TABLE>
Theres no need to yell at us...were here to help
yes you do need to take out the panels to get to your window. first you take out the panels, roll down the window until you can see the metal piece that makes it go up and down. Once you see it look for two nuts 1 on left and the other on the right. take those nuts off and you should be able to take out the window (slide it out to the top). then when u put on the new window, jus line up everything (holes for the nuts and windows lined up to the rubber on both side of the door) then bolt it back up. shouldn't be hard. takes some tries to get it right though.
RicanWitDaCivic
Honda Civic (2001 - 2005)
Oct 25, 2008 03:33 PM
v8destroyer
Dec 27, 2007 01:11 PM
rolledthatho
Sep 3, 2005 10:18 AM
Bo-C-Fuss
Apr 6, 2005 11:23 AM
