fs: jdm b16a sir2 cylinder head - 56k no
selling a '92-'95 jdm sir2 b16a head. pulled it off a '93 civic sir front clip with approx. 63k us miles on it. the head is fresh from the machine shop with new valves, valve seals, and valve job. was going to run the complete longblock but decided against it in favor of a different setup. the head has not been run since the machine work.
comes complete with the following:
cylinder head, camshafts w/cam gears, cam seal, valve cover, oil cap, valve cover gasket, spark plug o-rings, intake manifold w/sensors, throttle body, fuel rail, fuel pressure regulator, injectors, head studs, all nuts and bolts to reassemble(excluding valve cover grommets and nuts).
it DOES NOT have the distributor, vtec solenoid, and the throttle position sensor.
asking price is $550 obo. the head is already boxed up(two separate packages) and ready for its new owner. i'm located in texas, but am willing to ship at the owner's expense. shipping will be approx. $80-100 dependent upon your exact zip code(lower 48 states). i'm paypal verified and have tons of vouches.
if seriously interested, you can im or e-mail me directly at vtecb20coupe@hotmail.com. thanks in advance.
Modified by vtecb20coupe at 8:57 AM 12/19/2006
VNTEC
Jul 11, 2005 02:23 PM
