Quick spring related question?
Old Dec 18, 2006 | 07:25 AM
Fook_me_honda's Avatar
Default Quick spring related question?
I'm thinking about buying some B+G springs and its a 1.25 inch drop. Now when i put the springs back into the car will i have to compress them again? Its for a 93 accord if that helps.
Old Dec 18, 2006 | 08:03 AM
gosu08's Avatar
Default Re: Quick spring related question? (Fook_me_honda)
yes you have to compress the springs with a springs compresser inorder to put then on your struts/shocks then you put on the top hat and put the whole assembly back into your car.
Old Dec 18, 2006 | 11:41 AM
lxaccord51oxl's Avatar
Default Re: Quick spring related question? (gosu08)
yea u'll need to recompress the decompressed spring/strut. haha you use a kabobulator to do that. i tried to put on the spring/strut back on my car without compressing it before, and found out that the spring was out of place and not aligned up with the struts.. RECOMPRESS THE DECOMPRESSED WITH A KABOBULATOR
Old Dec 18, 2006 | 01:15 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Quick spring related question? (lxaccord51oxl)
With some springs this is not necessary though. When I re-installed my neuspeed sports after removing the factory springs, I did not have to compress them.... worked perfectly
Midori Green
10
Nov 24, 2007 06:12 PM
Understeer
Apr 1, 2005 11:32 PM
SD_EM1
Aug 13, 2003 11:40 AM
DiPPeD iN miLk Ej CoUpE
Jun 29, 2003 11:42 AM
