Anyone ever have this problem?
Old Dec 18, 2006 | 04:57 AM
teg969's Avatar
Default Anyone ever have this problem?
my wippers didnt work the other day..neither did my windshield washr fluid..so i though..ahh it must be the fuse...lean down...check and yes...its the fuse...satisfied because i figured the problem out....i change the fuse...give a click to the wippers....bam fuse blows out again....
now 2 things come to mind, 1) during the week end..a sever intense burning smell was comming from the interior of the car...i couldnt figure out what it is...anyway...it went away..buti couldnt locat any smoke..or nothing...
2) would i have a bad connection somewhere...why would out of the blue...my wippers would have a bad ground or something...anyone can help? where should i beguin checking?>
Old Dec 18, 2006 | 05:04 AM
john666's Avatar
Default Re: Anyone ever have this problem? (teg969)
who knows.. perhaps a bad wiper switch ? its fairly common the light switch goes bad so why not the wiper switch
Old Dec 18, 2006 | 05:17 AM
teg969's Avatar
Default Re: Anyone ever have this problem? (john666)
come to think of it..if it was the switch...it wouldnt keep blowing fuses it would jsut not work right??
Modified by teg969 at 2:31 PM 12/18/2006
Old Dec 18, 2006 | 06:31 AM
john666's Avatar
hard to say... if the switch is broken lets say it could either not work at all.. or cause a short that would kill a fuse.. could be a short mayb near the wiper motor ? u'd have to look and see
Old Dec 18, 2006 | 06:49 AM
teg969's Avatar
ill take a good look tonight..lucky for me the weather is nice
Old Dec 18, 2006 | 07:45 AM
Luserkid's Avatar
This is a really hard problem to look for. First off i would take off the panel thats right around the switch and look for anything that looks burnt out. Shorts are by far the most annoying and hardest things to look for. Take a day off to look for it. If you try on pressed time you probably wont find it.
Old Dec 18, 2006 | 08:45 AM
teg969's Avatar
Default Re: Anyone ever have this problem? (Luserkid)
true that but after reading a few threads on this subject..some say its the motor thats gone bad...and that i would need to change de motor as such...i dont get it...but anyway...its weird that it smelt so bad...i mean the intensity of the stench of burned plastique..was incredible....
ill try looking tonight
Old Dec 18, 2006 | 09:10 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">This is a really hard problem to look for. First off i would take off the panel thats right around the switch and look for anything that looks burnt out. Shorts are by far the most annoying and hardest things to look for. Take a day off to look for it. If you try on pressed time you probably wont find it. </TD></TR></TABLE>
True dat, you have no idea how many times I've spent 20 bux for an automotive electric shop to find a short .
Sometimes they're just annoying as hell and you can't find out where the hell they are .
Old Dec 18, 2006 | 12:37 PM
teg969's Avatar
Default Re: Anyone ever have this problem? (Syndacate)
ok supposedly its the wiper motor..when it sgoing like that..it takes to much amps to move so thats what makes it f*cked...
wseg
Mar 3, 2010 03:35 PM
supraken
Jul 23, 2007 07:43 AM
tournapart
Mar 16, 2005 01:15 AM
eric416
Dec 8, 2004 09:06 PM
rexdriver88
Aug 28, 2004 10:34 PM
