will itr valves and valve springs work on gsr?
Old Dec 17, 2006 | 10:00 PM
Ek_zErO's Avatar
Default will itr valves and valve springs work on gsr?
I have a 97 Integra GSR and i was wandering if JDM ITR or USDM ITR intake and exhaust valves work on a stock gsr valve guide etc..?? Also will the ITR dual valve springs work on GSR?
Old Dec 17, 2006 | 10:06 PM
lVlemphizStylez's Avatar
Default Re: will itr valves and valve springs work on gsr? (Ek_zErO)
yes
Old Dec 19, 2006 | 01:54 PM
jonshonda's Avatar
Community Builder
Default Re: will itr valves and valve springs work on gsr? (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
Old Dec 19, 2006 | 02:23 PM
doood's Avatar
been there done that
Default Re: will itr valves and valve springs work on gsr? (jonshonda)
itr and gsr exhaust valves are the same thing. only the intake valves are different.
Old Dec 19, 2006 | 04:50 PM
g2daturbo's Avatar
Default Re: will itr valves and valve springs work on gsr? (doood)
just about everything from a type r and a gsr is interchangeable.. the type r and gsr block are exactly the same including the crank... the pistons rods and head including cams, valves, valvesprings and intake manifold are the only differences
Old Dec 19, 2006 | 05:20 PM
Ek_zErO's Avatar
ok thanks alot
Old Dec 19, 2006 | 06:27 PM
str8JDMteggy's Avatar
If your going to spend the money on the type R valve springs you might as well just go buy aftermarket dual valve springs for intake and exhaust side for not much more.
Old Dec 19, 2006 | 07:24 PM
doood's Avatar
Default Re: will itr valves and valve springs work on gsr? (g2daturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2daturbo &raquo;</TD></TR><TR><TD CLASS="quote">just about everything from a type r and a gsr is interchangeable.. the type r and gsr block are exactly the same including the crank... the pistons rods and head including cams, valves, valvesprings and intake manifold are the only differences</TD></TR></TABLE>
the itr crank has two more counterweights and is heavier to withstand higher rpms
Old Dec 19, 2006 | 07:42 PM
Default Re: (str8JDMteggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8JDMteggy &raquo;</TD></TR><TR><TD CLASS="quote">If your going to spend the money on the type R valve springs you might as well just go buy aftermarket dual valve springs for intake and exhaust side for not much more. </TD></TR></TABLE>
not quite...you can pick up the entire ITR valvetrain for 100 bucks...I want to see you get retainers and springs for 100 bucks aftermarket...Hell someone was selling the ITR intake side for 30 bucks...
Old Dec 20, 2006 | 03:50 PM
I picked up port flow dual valve springs and retainers for 150$
Old Dec 20, 2006 | 09:12 PM
Ek_zErO's Avatar
ok thanks alot
Old Dec 20, 2006 | 09:13 PM
Ek_zErO's Avatar
Anyone has a obd2 gsr throttlebody,manifold with all sensor, and injectors for sale? Any of this item will do! I'm located in northern california. I need this item ASAP
Old Dec 21, 2006 | 05:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
FYI, GS-R has dual intake valve springs, which are the exact same part number as the ITR's dual exhaust valve springs. So all you need to buy are the ITR's intake valve springs, and you can swap your GS-R intake valve springs over to the exhaust side.
koratb
Nov 13, 2006 05:42 PM
1meanteg
Mar 11, 2006 06:30 PM
redlineintegra
Sep 20, 2005 10:43 PM
b19coupe
Sep 14, 2005 05:54 PM
