throw out bearing
Old Dec 17, 2006 | 07:51 PM
Baron55's Avatar
Default throw out bearing
So i have this sqeaking noise when my car is in neutral with the clutch engaged; but if a slightly tap the clutch...noise is gone. Anyways so its the throw out bearing right? IS there anyway to stop this without taking off the tranny??????
Old Dec 17, 2006 | 08:33 PM
JC95Int's Avatar
Default Re: throw out bearing (Baron55)
Yeah, its your throwout bearing, but I don't think you can do anything but replace it.
Old Dec 17, 2006 | 08:34 PM
95 integra's Avatar
engaged but slightly tap? If it makes no noise with the car in gear with the clutch "in/pressed" then its not the throw out bearing. If it makes noise with the car in neutral and the clutch "out" then its likely an input shaft bearing.
Old Dec 17, 2006 | 08:37 PM
8YourV8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">IS there anyway to stop this without taking off the tranny??????</TD></TR></TABLE>
um.... lol
but yeah i have the high pitched squeal and knocking noises from my throwout bearing. slight pressure to the clutch petal will stop the squeal but i have to push the clutch in all the way for the knocking to go away. throwout bearing shouldnt squeal with the clutch in... that's something else.
Old Dec 18, 2006 | 12:42 PM
Baron55's Avatar
well I already had my input shaft bearing changed and when I did the metal holders that hold the metal ***** inplace were broken..HOw the hell that happen??????? How did these bearings go bad? Funny thing is after i changed it, i sometimes hear the same noise slightly, but not as much; if i press in the clutch it goes away
But yeah i know that my throw out bearing is squeaking like a mouse, but its not always..So i guess i have to deal with it till i change or take off the tranny and lube it?
Old Dec 19, 2006 | 12:48 PM
Baron55's Avatar
up
Old Dec 19, 2006 | 06:25 PM
str8JDMteggy's Avatar
I have the same problem, its the throw out bearing. That thing pisses me off so badly at times but then it will randomly go away. Craziest thing is that its a brand new throw out bearing and pilot bearing, I did the clutch, relaced all the bearings and the second i drove it it squeeked. IT SUCKS.
H22_CB7_JAY
17
Feb 15, 2013 06:48 PM
vlc92189
Jul 23, 2006 05:01 PM
Aron Parsons
Mar 6, 2006 09:18 PM
AJxr
21
Jan 11, 2006 03:21 PM
pa2play
Jul 28, 2005 09:42 AM
