FS: PnP Autronic EMS for honda.
Old Dec 17, 2006 | 06:55 PM
wade's Avatar
Default FS: PnP Autronic EMS for honda.
selling my Autronic EMS. It is for a 92-95 OBD1 Honda. You can use it on obd-0 and obd-2 cars with the affiliated OBD adapter harness.
This is a Autronic SMC software.
This includes the Autronic Air temp sensor and coolant temp sensor.
Very powerful standalone ecu for your honda.
Has 2-step/antilag setup and much more.
You dont have to buy a 3bar mapsensor as the autronic has a built in mapsensor.
You don't have to install a resistor box onto your car either when you move up to larger cc impedance injectors.
# Sequential operation for 2 to 8 cylinder engines.
# Eight injector ouputs.
# Four ignition outputs
# 3D fuel and Ignition maps.
# User defined up to 32 RPM and 16 Load sites = 512 sites.
# Anti-Lag.
# Flat Shift (ver 1.19).
# Data Logging.
# Software selectable trigger angle.
# Support for multi-tooth or missing teeth triggers.
# Auxiliary outputs other than fuel pump control
# 8 cyl engine = 1 (1 PWM output).
# 6 cyl engine = 3 (1 PWM + 2 On/Off)
# 4 cyl engine = 5(1 PWM + 4 On/Off)
# Auxiliary outputs can be defined for boost control, nitrous oxide, camshaft
# timing, AC, fan control, idle valve etc...
# Available with high current drivers if required.
# AutoTune option available.
New retails for 2,000.
ASking 1,500.OBO
Old Dec 18, 2006 | 01:03 AM
itr_18's Avatar
Propably its no the best idea to create new thread just to sale something. Here is place where you should post it! https://honda-tech.com/zerothread/1640902
But... up for great ECU
LightningTeg
Engine Management and Tuning
Apr 1, 2016 04:43 AM
wade
Dec 22, 2006 05:30 PM
Binary
Aug 18, 2004 10:04 AM
