is the type-s and the type-r the same engine?
Old Dec 17, 2006 | 06:41 PM
enzozenuni's Avatar
Default is the type-s and the type-r the same engine?
is the type-s and the type-r the same engine? just different name...
Old Dec 17, 2006 | 06:45 PM
gurlracer_camille's Avatar
Default Re: is the type-s and the type-r the same engine? (enzozenuni)
no way, type r is way better and stronger than the type s... ive seen a type s with a i/h/e and k-pro still lose to a type r. the k20a engine is way better than the k20a2...
Old Dec 17, 2006 | 06:46 PM
enzozenuni's Avatar
Default Re: is the type-s and the type-r the same engine? (gurlracer_camille)
whats the difference? also whats the difference between the b16b and the b16a?
Old Dec 17, 2006 | 06:53 PM
9bells's Avatar
OG Fabricator
The type-r has better intake,header,cams, intake manifold, and different gearing with shorter final drive. It would win many races against bolt-on type-s'.
The b-series stuff somebody else can answer.
Kantot's Avatar
im not gonna flame you. but you should do your research at least. i simply typed in b16 into google and found this.
http://en.wikipedia.org/wiki/Honda_B_engine
Old Dec 17, 2006 | 07:25 PM
enzozenuni's Avatar
Default Re: (Mr.Kantot)
thanks for the help guys!
Old Dec 17, 2006 | 08:10 PM
TheMuffinMan's Avatar
He knows where you live!
lol if you're referring to a ITR - it's a B18C5 for the USDM and I believe B18C for the JDM
please research
Old Dec 17, 2006 | 08:29 PM
Kantot's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">lol if you're referring to a ITR - it's a B18C5 for the USDM and I believe B18C for the JDM
please research </TD></TR></TABLE>
i think he is talking about a DC5 since he is in the rsx forum
Old Dec 18, 2006 | 08:58 AM
dc5tegk20's Avatar
k20a + k20a2 = k20z1 the best of both worlds the Z has type-r parts in it such as nitake minfold and final drive and ehaust and intake components
Old Dec 18, 2006 | 09:11 AM
mikestypes's Avatar
Default Re: (dc5tegk20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5tegk20 &raquo;</TD></TR><TR><TD CLASS="quote">k20a + k20a2 = k20z1 the best of both worlds the Z has type-r parts in it such as nitake minfold and final drive and ehaust and intake components </TD></TR></TABLE>
The z1 does not have a type-r intake manifold, nor does it have the 11.5:1 pistons that the TypeR has. The intake snorkel and the exhaust b-pipe are PRC part numbers, but these parts (intake and exhaust) are all swapped out for better stuff 99% of the time anyway.
The important things like the block, crank, rods, and head are all identical.
In most cases, all that is better engine wise on a complete swap is the extra .5 compression and the slightly better cams (comparing an A to and A2, a Z1 would only be the pistons.)
951kader
Jan 29, 2012 09:30 PM
03dc5Ray
May 18, 2008 12:37 AM
B18C5-EH2
Mar 21, 2005 03:56 PM
PePpeRedDc5
Mar 2, 2005 03:54 PM
Mac
Dec 9, 2001 04:09 PM
