Another "Bitch Pin" question
Old Dec 17, 2006 | 05:57 PM
I CRX I's Avatar
Default Another "Bitch Pin" question
is it easier to hammer pin out from bottom or top? i curently have my motor and trans out of the car so its near impossible to hammer from the bottom
Modified by I CRX I at 7:13 PM 12/17/2006
Old Dec 17, 2006 | 06:38 PM
I CRX I's Avatar
im not getting anywhere hammering from the top, any special ways you guys did it , im having problems clearing the tranny for a clean wack at the pin, has anybody ever gotten the thing out hammering at an angle from the top?
Old Dec 17, 2006 | 06:47 PM
sporkcrx's Avatar
Default Re: (I CRX I)
I've always just hammered it out with a punch from the bottom with no problems. I dont know if everyone's just gets mangled or what. Are you using a punch, or a bolt or what?
Old Dec 17, 2006 | 06:58 PM
SloAssHB's Avatar
Default Re: (sporkcrx)
I did mine from the bottom and was a pita...a lot of hammering but once its loose it comes right out. I soak min with penetraiting fluid and used a punch and 4lb sledge and 15 minutes later it came out
Old Dec 17, 2006 | 06:59 PM
Crx Jimmy's Avatar
Default Re: Another "Bitch Pin" question (I CRX I)
you need one of these
http://www.cheaptrixracing.com/for_sale.htm
Old Dec 17, 2006 | 07:16 PM
eda6's Avatar
Default Re: Another "Bitch Pin" question (Crx Jimmy)
bitch pins aren't a bitch.
Old Dec 17, 2006 | 07:19 PM
HamiltonRex's Avatar
Default Re: Another "Bitch Pin" question (eda6)
ummm.. you can hammer it out eaither way, since the pin is like a spring kinda. I used slight heat directly on the pin, but kept a COLD rag on the bushings so they dont melt.. and kept a bucket of ICE watter right beside me, heated it for 5 sec's, came out in 2 taps, then once it was pulled apart i dunked it in the cold water.. this way the heat didnt travel though the steel fast enough to melt the bushings in that part of the linkage.
Just get the proper tool you tool
Old Dec 17, 2006 | 09:33 PM
JakeSpec's Avatar
Very Easy use an A/C 12mm Bolt and a good 4LBS hammer! FROM BOTTOM Up
Old Dec 17, 2006 | 10:39 PM
kixcrx's Avatar
Default Re: Another "Bitch Pin" question (JakeSpec)
i just used some screw driver that i had laying around and smack the **** out of it and it came out
Old Jan 16, 2007 | 06:14 PM
bravo76's Avatar
hi jimmy can u help ?? please to tell how can i take out that alternator form my acura 90
Old Jan 16, 2007 | 06:36 PM
94_DC4's Avatar
Use a bolt from the AC compressor then hammer it out from the bottom.
Old Jan 16, 2007 | 06:59 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: Another "Bitch Pin" question (94_DC4)
8mm punch for an 8mm pin. It's as simple as that.
Old Jan 16, 2007 | 07:17 PM
.Thomas's Avatar
Default Re: Another "Bitch Pin" question (ILcrxsi1)
remove it from the shift linkage? 12 mm bolt is was easier
Old Jan 16, 2007 | 07:40 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">you need one of these</TD></TR></TABLE>
I bought one when he first came out with them.
Broke 1st time I used it.
Old Jan 17, 2007 | 12:13 AM
Cheeech's Avatar
Default Re: Another "Bitch Pin" question (Tippyman)
I used a drill bit slightly bigger the the pin and hammered the **** out of it, work like a charm, but still a pain in the ***.
Old Jan 17, 2007 | 12:36 AM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">8mm punch for an 8mm pin. It's as simple as that.</TD></TR></TABLE>
Thats what I say, I have hammered out over 100 shift pins and never had a problem. I don't understand how people have problems with these.
Old Jan 17, 2007 | 05:53 AM
blah13's Avatar
Default Re: Another "Bitch Pin" question (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">
Thats what I say, I have hammered out over 100 shift pins and never had a problem. I don't understand how people have problems with these.</TD></TR></TABLE>
Girly men, nuff said.
Swing that hammer/small sledge with some *** behind it, or go ask your mom.
Old Jan 17, 2007 | 06:21 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Another "Bitch Pin" question (blah13)
I noticed you said the motor is out the car. Just take the tranny off it takes like 5 minutes if that. Flip it upside down and use a 1/4 extension and hammer and tap it out. Thats what I have always done for years and it works. Or you can go buy a 0.8mm punch from snapon but thats $$$.
Old Jan 17, 2007 | 06:29 AM
dr_latino999's Avatar
Thats what I say, I have hammered out over 100 shift pins and never had a problem. I don't understand how people have problems with these.</TD></TR></TABLE>Do you or anyone else have issues with the pin mushrooming when you re-install the new one?
Old Jan 17, 2007 | 09:28 AM
Tippyman's Avatar
Default Re: Another "Bitch Pin" question (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Do you or anyone else have issues with the pin mushrooming when you re-install the new one?</TD></TR></TABLE>
Use a peice of wood to get it started. Once it's fairly deep in there, just whack it.
(no "that's what she said comments, please..."
Old Jan 17, 2007 | 09:29 AM
snowseeker's Avatar
Not really, if you sit there and hit the pin 100 times like a puss it will mushroom out but if you get 4-5 good hits on it to get it in, it is normaly fine.
Old Jan 17, 2007 | 10:02 AM
shortyz21's Avatar
i grinded the end of my air hammer bit to fit that ******* pin.
&lt;3 air hammer. expletive manual labour.
blah13 how the hell do you swing a sledge laying under a car.. this i have to see.
Old Jan 17, 2007 | 10:22 AM
Default Re: Another "Bitch Pin" question (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote"> iblah13 how the hell do you swing a sledge laying under a car.. this i have to see.</TD></TR></TABLE> And don't say lift, because the highest the majority of us can work is the space provided by a really tall set of jack stands.
oj5joker
Aug 31, 2009 04:28 PM
E.
Jun 4, 2008 05:08 PM
djsire
Aug 31, 2005 10:29 AM
turbotime
11
Jun 25, 2004 08:22 AM
gsr-2nr
Nov 21, 2003 10:00 PM
