Intake making whistling sound.
Old Dec 17, 2006 | 04:18 PM
Rob.'s Avatar
Default Intake making whistling sound.
why is my intake making a whistling sound when I give it gas or blip the throttle ?
I have a stock intake, I took out the rubber "Y' snorkel at the bottom of the intake and it started to make a noise.
I put it back on there , but its still making that noise.
its my 1990 civic si.
Old Dec 17, 2006 | 04:23 PM
Custom Rex's Avatar
Default Re: Intake making whistling sound. (Rob.)
clean your air filter?
Old Dec 17, 2006 | 04:40 PM
hybridmiklo's Avatar
Default Re: Intake making whistling sound. (Custom Rex)
cause you are sucking in air.
Old Dec 17, 2006 | 04:50 PM
Rex-Si's Avatar
You have PM...........
Old Dec 17, 2006 | 04:53 PM
Rex-Si's Avatar
Default Re: Intake making whistling sound. (Rex-Si)
Its the throttle air adjustment screw just above the throat of the throttle body...
It has vibrated clock wise over time and now the tip of the screw acts like a reed and resonates this sound. Fought this problem for 6 months before i found the problem......turn that flat head screw counter clockwise about 1 to 1 1/2 turns and the sound will go away and your idle will smooth out a bit as well.
Old Dec 17, 2006 | 04:54 PM
Rob.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex-Si &raquo;</TD></TR><TR><TD CLASS="quote">You have PM........... </TD></TR></TABLE>
thanks, I'll try adjusting the idle screw.
justinCO
Jul 11, 2008 09:59 AM
100miles+
Honda Civic (2006 - 2015)
Feb 17, 2008 01:22 PM
Ser1N
Jun 15, 2004 12:36 PM
omeara7
May 3, 2004 02:16 PM
WangChung
18
Apr 10, 2003 06:11 PM
