How do I remove GSR molding for the type R look, and stop the auto Antenna???
Hey guys,
Is the GSR molding just stuck on to the car, or does it have the square holes like a civic? I want to take it off but if it has the holes then I do not. Just wondering b/c I put JDM thin molding on my EK and it hadl holes (clip type), also how can I stop the auto antenna? Im sure there is a wire/plug to pull, but where? Thanks for the help.
the molding is clipped in, there are square holes when you remove the molding. as for the antennae, just unplug it. you'll have to pull the plastic panel back in the trunk to get to it.
ok thanks man. just wondering cause I dont have the cash to get the holes patched and painted. Thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper »</TD></TR><TR><TD CLASS="quote">the molding is clipped in, there are square holes when you remove the molding. as for the antennae, just unplug it. you'll have to pull the plastic panel back in the trunk to get to it.</TD></TR></TABLE>
You can also just not hook up the wire that leads to the antenna from the cd player.
It's better to just leave the side moldings on, i really cant tell the difference between regular and type r. As for Antenna. . . just convert to s2k antenna if you have the money if not. . . its easier to unplug the power from the trunk.
Hanmin
Mar 22, 2008 12:29 PM
