car still not starting
Old Dec 17, 2006 | 02:10 PM
RyanG's Avatar
Default car still not starting
Ihave a 1990 acura integra B18A1 and it only has a greddy exhaust i dont think thad would make it not start because it ran befor
i have had a few people tell me that it could be the battery but when i switched the battery it still did nothing. i have checked all the ground wires and cleaned and tightned them. i have checked all the fuses and they were all good and we checked one of the relays that was clicking under the dash on the passenger side and it was getting power to both the big wires and the small ones were for the ground. so i dont know what now i even hooked the jumper pack up tp the starter and it turned over slowly my friend took it to his work and it tested out fine.
i was wondering if it could be the main relay under th dash on the driver side?
Old Dec 17, 2006 | 09:21 PM
1badteg's Avatar
check your positive and ground cables sometimes they are corroded or just not connected well. its happened to 3 of my cars. the battery was always good too. you get a ignition tone, then when you turn it over it clicks and everythings out. hope this helps.
Old Dec 18, 2006 | 01:15 AM
Danziver's Avatar
Default Re: car still not starting (DAtegfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAtegfreak &raquo;</TD></TR><TR><TD CLASS="quote"> so i dont know what now i even hooked the jumper pack up tp the starter and it turned over slowly my friend took it to his work and it tested out fine.
Ignition switch?
Old Dec 18, 2006 | 01:18 PM
RyanG's Avatar
Default Re: car still not starting (Danziver)
thanks for the help i was kind of starting to think that it was the ignition switch
Old Dec 18, 2006 | 04:10 PM
Danziver's Avatar
I have one for a dc if you have a hard time finding one. Im not sure if it will work on a DA though.
flood
16
Jul 12, 2013 04:40 PM
silentkid
Mar 3, 2010 11:59 AM
extensioncordy
34
Jan 30, 2007 03:38 PM
FindingEmo
Aug 5, 2004 06:46 AM
Jonathan_ED3
20
Apr 9, 2004 08:00 AM
