Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ANSWER ASAP Blown Shock?
Old Dec 17, 2006 | 12:00 PM
Sean DM's Avatar
Default ANSWER ASAP Blown Shock?
ok so since i lowered my car with the tein S techs instead of Skunk 2 coilovers
everything has been fine
untill today.
i noticed my left rear tired was extremely slammed it was really low prolly a 2.6 drop compared to the others which are 1.5.
when i push on the rear to make that size move it bounces quite a bit but when i do it to the o ther side it doesnt.
this will suck if it is blown..
Old Dec 17, 2006 | 12:13 PM
Sean DM's Avatar
Default Re: ANSWER ASAP Blown Shock? (Sean DM)
btw i have tokico blues
Old Dec 17, 2006 | 01:45 PM
Miracle's Avatar
Sounds like it is blown to me... Have you driven it since? Noises? Ride height/quality?
What happens when a shock blows, is that the seals that seal the piston in it's cylinder go out, allowing the shock absorber oil to leak out, thereby having no damping power at all. Hence, the MUCH lower ride height, and possibly noise and ride quality.
Think of it as piston rings going out in the motor... you lose compression, and therefore, lose power.
Old Dec 17, 2006 | 01:54 PM
Sean DM's Avatar
Default Re: ANSWER ASAP Blown Shock? (Miracle)
yea i checked and there is fluid from the shock all over.
THIS SUCKS!
it droped by .5 " too
now i just have to remmber where i put my warranty card...
Old Dec 17, 2006 | 02:03 PM
Miracle's Avatar
For those that do not know:
From my experience, this is the BASIC setup of how a shock is on the inside... VERY BASIC... And ignore my crude Adobe Photoshop painting skills too.
When the green seals wear out and leak, the piston inside the shock body have noting to push against, therefore making the shock lose it's dampening capabilities... Like I said before, it is just like wearing piston rings in the engine.
Hope that helps.
And for the record...
See the holes in the piston "disc" itself? On adjustable shocks, that is what actually gets bigger or smaller inside the shock that gives the shock it's adjustability.
Larger hole in the piston: Softer dampening
Smaller hole in the piston: Stiffer dampening.
Modified by Miracle at 5:26 PM 12/17/2006
Modified by Miracle at 5:28 PM 12/17/2006
Old Dec 17, 2006 | 04:11 PM
03EM2guy's Avatar
..that sounds blown to me but i wouldnt base it off of my opinion .....ask matt or fred, they will know
Old Dec 17, 2006 | 05:05 PM
Sean DM's Avatar
Default Re: ANSWER ASAP Blown Shock? (03EM2guy)
ya theyre blown i see the greese n **** all over..
DAMITTT
anyone selling a single L-R tokico shock? lol
Old Dec 17, 2006 | 05:57 PM
Vantage's Avatar
ouch man that sucks. Id be pissed if i bought aftermarket shocks and they were already blown
Old Dec 17, 2006 | 06:45 PM
Sean DM's Avatar
Default Re: (Vantage)
well i wouldnt be so pissed if they were cheap but they are tokico blues i mean come on
and only 1 of them blew.
Old Dec 17, 2006 | 07:36 PM
Todd00's Avatar
I said I don't want a title!
Default Re: (Sean DM)
Tokico has a warranty. May want to contact them.
Old Dec 17, 2006 | 07:49 PM
Curiouz_G's Avatar
all the more reason to go Koni's
Old Dec 17, 2006 | 07:51 PM
Sean DM's Avatar
Default Re: (Curiouz_G)
Ya i was goin to then i remmber it was sunday lol
hopefully i can do it without my warrenty card ****.
Old Dec 18, 2006 | 07:26 AM
iwantspeed's Avatar
anyone heard of KYB shocks? they any good?
Old Dec 18, 2006 | 08:04 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: ANSWER ASAP Blown Shock? (iwantspeed)
I've heard of them... think they're pretty good if i remember rightly. Don't quote me on that though...
Old Dec 18, 2006 | 12:15 PM
mrtrinh's Avatar
Default Re: ANSWER ASAP Blown Shock? (ONLYuk7thGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Tokico has a warranty. May want to contact them.</TD></TR></TABLE>
Yeah you should be able to do it w/o a warranty card, they come with a lifetime warranty as long as you don't lower your car below 1.5" and they will inspect it (i warrantied one of my shocks as well)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwantspeed &raquo;</TD></TR><TR><TD CLASS="quote">anyone heard of KYB shocks? they any good?</TD></TR></TABLE>
KYB's are pretty good, gr-2's ride similar to tokico blue's but like them, they are not for tracking or autox, just for daily driving... while kyb agx's are adjustable and can be used for performance but not as good as koni yellows
JDM EJ2
21
Jul 24, 2009 10:39 PM
R1C3Rxs
Mar 26, 2008 12:08 PM
goldegg
Suspension & Brakes
Sep 25, 2007 07:47 AM
LaOstha
Aug 23, 2005 09:32 PM
Soled Out
Jun 1, 2002 07:55 AM
