valve clearance questions?
Old Dec 17, 2006 | 08:32 AM
si90rex's Avatar
Default valve clearance questions?
i'm building a b16a with ctr oversized pistons. I'm worried about valve clearance with stage 2 sk2 cams? Is this possible? i called skunk2 and asked for specs they said there only .007. i searched a bit but didn't know what to search for really. please any help would be great.
Old Dec 17, 2006 | 01:14 PM
95 integra's Avatar
Default Re: valve clearance questions? (si90rex)
Im thinking they were talking about valve lash and not piston-to-valve clearance. Do a search, this has been addressed many times previously.
Old Dec 18, 2006 | 07:54 AM
Player5530's Avatar
you wont have any prob with this setup my friend has this setup and no piston to valve contact. Just degree the motor if you have the time and or resources to do it. If not keep the cam degrees together dont seperat it alot. "Stage II: Stage II profiles are more aggressive than Stage I profiles, and are designed for modified engines operating at higher rev ranges. Upgrading to Skunk2 Racing valvetrain components is required for proper operation. Stock idle and emission characteristics may be slightly compromised, but fair-to-good driveability allows them to still be used on dual-purpose vehicles. Proper tuning, an upgraded intake system, and an exhaust system are required in order to maximize the potential of these camshafts. Do not use oversized valves." taken straight from skunk2 website
http://www.skunk2.com/Merchant...e=CAM
Old Dec 18, 2006 | 04:53 PM
si90rex's Avatar
Default Re: (Player5530)
thanks but i know about the dual springs. the put sk2 high comp valves, springs, and retainers. i just wanted to know if i would have a clearance issue, with the stage 2 cams and oversized ctr's.
thanks for the help.
Old Dec 18, 2006 | 05:07 PM
alterdcreations's Avatar
Default Re: (si90rex)
clay your engine for safe measure
SiKtEg101
Dec 21, 2005 11:52 PM
JDMotive
Jun 5, 2004 10:14 PM
nY's FiNeSt
May 3, 2004 08:10 AM
boredracer408
Feb 21, 2004 05:09 PM
ActiveAero
Jul 12, 2003 08:29 AM
