B16 questions
Old Dec 17, 2006 | 08:27 AM
crxpwr1's Avatar
Default B16 questions
1.) Well I was looking at this and I was wondering If I could take this off and what is it for? The thing that says up on it
2.) I was wondering what this one does also and can I take it off
3.) what does this hose run to and what is it for?
4.) I was wondering what this is for and what it does?
Thank you in advance
Old Dec 17, 2006 | 09:03 AM
Crx Jimmy's Avatar
Default Re: B16 questions (crxpwr1)
1) remove it it doesnt do anything all the newer b16 dont have this
2)remove it it doesnt do anything all the newer b16 dont have this
3)Looks like to main fuel line from your filter you will need a new one from honda you cannot cut these and clamp back together
4)thats to your heater core it connects on the side of your motor under the dizzy
Old Dec 17, 2006 | 09:19 AM
143MYVTECEF's Avatar
Default Re: B16 questions (Crx Jimmy)
Yup confirmed
Old Dec 17, 2006 | 11:28 AM
civic89si666's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">1) remove it it doesnt do anything all the newer b16 dont have this
4)thats to your heater core it connects on the side of your motor under the dizzy</TD></TR></TABLE>
^^^ CRX JIMMY knows what hes talking bout
Old Dec 17, 2006 | 11:51 AM
crxnj's Avatar
Default Re: B16 questions (civic89si666)
Those things in the 1st 2 pics are called dashpots..true you dont need them,,but they keep the engine from dropping revs to fast...i took mine off though and it runs the same
Old Dec 17, 2006 | 02:55 PM
crxpwr1's Avatar
Default Re: B16 questions (mr.speaker)
what do I do with the hoses that run to it?
Old Dec 18, 2006 | 04:36 AM
crxpwr1's Avatar
bump
Old Dec 18, 2006 | 05:30 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 &raquo;</TD></TR><TR><TD CLASS="quote">what do I do with the hoses that run to it?</TD></TR></TABLE>
cap them off with vacuum nipples/plugs
Old Dec 18, 2006 | 05:51 AM
PACT man's Avatar
Default Re: B16 questions (Autoworks)
#4 while it does lead to the heater core, that actual part is the heater valve. It controls the flow to teh heater core for blending in heat for inside the cabin.
kanzenr91si
Jun 11, 2003 04:27 PM
