B16 cold air intake in Crx?
Old Dec 17, 2006 | 07:58 AM
crxpwr1's Avatar
Default B16 cold air intake in Crx?
I put my cold air intake on today but I dont know what do do with these hoses so I can hook up the hose that runs from the piping to the vc
that blue hose in the last pic is the hose that cam with the intake
Modified by crxpwr1 at 9:18 AM 12/17/2006
Old Dec 17, 2006 | 08:01 AM
crxnj's Avatar
Default Re: B16 cold air intake in Crx? (crxpwr1)
the intake didnt come with any nipples for those hoses?
Old Dec 17, 2006 | 08:02 AM
crxpwr1's Avatar
Default Re: B16 cold air intake in Crx? (mr.speaker)
yea it came with a nipple Ill show you a pic of it sitting in the car
Old Dec 17, 2006 | 08:07 AM
Loserkidwac's Avatar
Well you have a fe options, for my turbo set-up since I didn't want to feed boost into my valve cover i just put a filter on the VC and left the metal thing just sitting there...
I think Ideally you should have it hooked up to pull oil vapers back into the motor to be burned...
Old Dec 17, 2006 | 08:12 AM
crxpwr1's Avatar
Default Re: B16 cold air intake in Crx? (Loserkidwac)
hold up let me rephrase my question can I just unplug all those hose that are in that picture and just hook up a hose running from the piping to the vc
Old Dec 17, 2006 | 08:17 AM
crxnj's Avatar
if the new intake tube only has one nipple you could put just the lower hose to it,,then put a breather filter on the valve cover like loserkid said..
Old Dec 17, 2006 | 08:20 AM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">if the new intake tube only has one nipple you could put just the lower hose to it,,then put a breather filter on the valve cover like loserkid said..
I would never do that, just run a hose to the ground, WHy filter air coming out? Those things clog up and your pressure inside the motor goes up. Let it breath free
Old Dec 17, 2006 | 08:22 AM
crxnj's Avatar
Default Re: B16 cold air intake in Crx? (Boosted Chemist)
I would never do that, just run a hose to the ground, WHy filter air coming out? Those things clog up and your pressure inside the motor goes up. Let it breath free </TD></TR></TABLE>
yeah,,just trying to help the environment..even though it's already shot.
Old Dec 17, 2006 | 08:24 AM
yeah,,just trying to help the environment..even though it's already shot.</TD></TR></TABLE>
You could run the hose to a catch can and empty it in your oil drainpan. I run mine to the ground, most of hte bad **** is caught in my catch can off the back of the block.
Old Dec 17, 2006 | 08:31 AM
crxpwr1's Avatar
I was wondering If I could just run it like this?
but if I do what am I soppuse to do with all the hoses that run everywhere
Old Dec 17, 2006 | 09:57 AM
one hose is a vac line the other is a coolant line...you can get rid of the metal hose if you run the hose as pictured for the oil vapors and then run a new coolant line
KodSol
Dec 4, 2011 07:39 PM
coot_er
Mar 29, 2009 09:26 PM
ghostlude99
Oct 12, 2008 10:09 AM
DelSol941
Oct 11, 2003 08:34 PM
h22congee!
Oct 5, 2002 11:30 AM
