Tuning help!
I will start by saying that I have complete confidence in my tuner and am very very happy with my results. My setup is as follows.
gsr block with ctr pistons
mildly ported b16 head
jun 4 cams
jun valve springs
skunk retainers
dtr street sweeper header
apexi power fc
Now I know that the motor is over cammed however my tuner got it to run and idle pretty well. The motor made 206whp and 140 tq with a stock b16 im and throttle body. My question is this: At night the car does not want to idle. I have noticed that when I turn my lights off it runs a lot better. Is this something that can be corrected simply with a new battery or voltage stabilizer? If not can this be tuned out? In a couple weeks I will be re-tuning (ported itr manifold and a bigger throttle body) should I just wait till then to try to figure this out?
Thanks for any input!!!
jun 4 cams
jun valve springs
skunk retainers
apexi power fc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUNEK9 »</TD></TR><TR><TD CLASS="quote"> Now I know that the motor is over cammed </TD></TR></TABLE>
More like over compressed............CTR pistons FTL
It sounds like you have a weak/bad alternator. If you have underdrive pulleys it will probably do the same. The battery could also be getting weak (being it can help stabilize the power loss at idle and make up for it at higher rpms).
JdmEg6Hybrid
12
Nov 22, 2005 08:47 AM
PanamaVTI
23
Oct 20, 2003 10:01 AM
