Water pump..
Old Dec 17, 2006 | 07:01 AM
Inliner's Avatar
Default Water pump..
I purchased a 94-95 GSR water pump and i am wondering if this water pump will fit an LS engine?
Old Dec 18, 2006 | 11:56 AM
Inliner's Avatar
someone has to know this....
Old Dec 18, 2006 | 12:07 PM
Rigginit's Avatar
Default Re: (Inliner)
IM'd
Old Dec 18, 2006 | 02:38 PM
Brick Top's Avatar
Default Re: Water pump.. (Inliner)
what year is the block? code on block?
b18a, b18b then yes
Old Dec 18, 2006 | 05:19 PM
qfast817's Avatar
Default Re: Water pump.. (brick top)
i think it will, count the teeth on the pump
Old Dec 19, 2006 | 12:39 PM
havok hybrid's Avatar
gsr water pump will bolt on to your LS block.. you will need a gsr timing belt in order to use the gsr pump..
Timing belt and water pump have to match.. no matter what b18 motor you are using.
B00sted Eg2
May 7, 2009 01:34 PM
19sec beast
Mar 31, 2006 04:40 AM
dartdc97
Oct 27, 2005 01:08 PM
87ludemasta
Dec 30, 2004 11:58 PM
92SiBlu
Apr 18, 2004 03:09 PM
