1992 Toyota Celica Alltrac, TURBO / AWD, $4900!!! GREAT Shape
Old Dec 16, 2006 | 10:30 PM
Attoir's Avatar
Default 1992 Toyota Celica Alltrac, TURBO / AWD, $4900!!! GREAT Shape
Located in Atlanta, TX.
Contact Information
903-691-5378 (Joseph) u8me@hotmail.com, AttoirRE (AIM)
Year
1992
Make and Model
VIN
JT2ST88PONOO22631
Mileage
162XXX
Transmission Type
Manual
Title Status
Clear
Price
4900!!! NO LOWER, NO TRADES
Mods (if yes please list below)
Yes
Additional information
XTD 12lbs lighweight flywheel
Brand new TRD Street clutch ($$$$)
JDM Top mount IC (A little thicker than USDM
3" Downpipe
3" Midpipe, 2.5" rear section
Straight intake
Relocated battery
MBC Set at 10psi
Faze boost gauge
'02 Celica GT-S 16" wheels w/ Kumho Ecsta TA's with 90% tread on all four. (Still have stocker 15" wheels, tires have prolly ~40% tread left)
GT-Four (JDM) rear badge
New OEM timing belt
OEM Timing belt tensioner + idler pulleys
Toyota water pump
New oil pan gasket
Both front axles have been replaced.
New OEM wheel bearing installed by Toyota
All new accessory belts.
I have many of the maintence reciepts.
Fresh paint, dark red metallic, with hood vents painted black. Car looks GREAT as you can see in the pics.
Interior is in EXCELLENT shape with exception of the single cig burn on headliner (super tiny, smaller than a dime), and the dirty pass carpet (floormat covers it up).
Now, the bads:
AC lines are hooked up, new (used) compressor, everything SHOULD be ready for a charge, but no promises.
Speedo doesn't work, needs new cable. I drive by RPM's in 5'th gear.
Leak from oil pan gasket. Was supposed to use RTV only, I used a Felpro. Didn't work.
Small exhaust leak (needs new gasket between midpipe / axle back)
Car got keyed, and a small dent on the pass side of the car. Key scratch isn't gonna show up in pics, dent will somewhat. Pretty minor. I wouldn't bother fixing it.
One cigarette burn in the interior.
Exhaust rattle at about 4k RPM's.
Pass side carpet is a little dirty, shampoo would probably get it clean.
High mileage, 160k. Motor runs awesome, and pulls strong. Turbo has very minimal shaftplay, doesn't smoke, and spools quickly. 0 issues out of it. I would drive it anywhere.
These cars are ***RARE***. These were made by Toyota to compete in the rally circuit. I purchased this car w/ a bad clutch from an Air Force guy. He didn't have time / money to get it fixed. I purchased it, put on the 3" downpipe, straight intake, and clutch. The car is now registered in my name, and the (Texas) title is on the way here from the DMV. There are no issues w/ the title. It's clean.
http://www.access903.com/Celica/Celi4.jpg
http://www.access903.com/Celica/Celi5.jpg
http://www.access903.com/Celica/Celi6.jpg
http://www.access903.com/Celica/Celi7.jpg
http://www.access903.com/Celica/Celi8.jpg
http://www.access903.com/Celica/Celi9.jpg
http://www.access903.com/Celica/Celi10.jpg
http://www.access903.com/Celica/Celi11.jpg
http://www.access903.com/Celica/Celi12.jpg
http://www.access903.com/Celica/Celi13.jpg
http://www.access903.com/Celica/Celi14.jpg
http://www.access903.com/Celica/Celi15.jpg
http://www.access903.com/Celica/Celi16.jpg
http://www.access903.com/Celica/Celi17.jpg
http://www.access903.com/Celica/Celi18.jpg
http://www.access903.com/Celica/Celi19.jpg
98CivB18C
Feb 3, 2012 12:36 PM
Attoir
Texas -OK -LA (Sales)
Dec 17, 2006 03:57 PM
chet
Nov 25, 2006 06:01 AM
