Anyone know of a fairly cheap bead roller capable of doing your basic stainless charge pipes?
Old Dec 16, 2006 | 09:48 PM
RC000E's Avatar
Default Anyone know of a fairly cheap bead roller capable of doing your basic stainless charge pipes?
I know the HF one is supposedly ****. Anyone know of anything affordable that can put a good bead in your typical stainless charge pipes?
Old Dec 17, 2006 | 01:04 AM
F20Cteg's Avatar
Default Re: Anyone know of a fairly cheap bead roller capable of doing your basic stainless charge pipes? (R
Bead Form is a really nice quality device. It is just over $400 so I don't really think of it as affordable, but depending on how many you need to do, it just might be worth it.
Me, I just weld three 1/2" long beads on the end of pipes.
Old Dec 17, 2006 | 09:14 AM
RC000E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">Me, I just weld three 1/2" long beads on the end of pipes.</TD></TR></TABLE>
Exactly....that's gettin old! I just like to maintain quality on installs and kits I put together for people. Doing the weld bead just is slightly ghetto versus a true bead. Just lookin to upgrade if there is something out there. I'm gonna check that piece out that you have up there.
Old Dec 17, 2006 | 09:20 AM
Race Egr's Avatar
The cheapest one I have found that will do 16 gauge tubing is 1k. Trick tools has alot of them check out there site
Old Dec 17, 2006 | 09:25 AM
Top Ramen's Avatar
Here's the Bead Form:
http://www.eastwoodco.com/jump...ODUCT
Old Dec 17, 2006 | 10:37 AM
CBURKE's Avatar
I wish I could find it on here, but there was a guy that made his own using a power steering pully and some othere thing he fabed up.
Old Dec 17, 2006 | 11:14 AM
RC000E's Avatar
Default Re: (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">I wish I could find it on here, but there was a guy that made his own using a power steering pully and some othere thing he fabed up.</TD></TR></TABLE>
Ha! I remember that thread...that was a while ago. It was definitely good **** though. I thought I recalled him using an a/c compressor bracket or something. Definitely remember what your talking about.
Old Dec 17, 2006 | 11:17 AM
RC000E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen &raquo;</TD></TR><TR><TD CLASS="quote">Here's the Bead Form:
This here looks like it might be the ticket...pretty affordable and fairly quality lookin.
Old Dec 17, 2006 | 02:00 PM
dave@passenger's Avatar
I have a beadform, its the heavy duty one with replaceable bearings and stuff, I think it was like $480 or something like that. I bought it from tricktools. Its a really nice unit, does 16g carbon steel, stainless steel, Al with no issues, just make sure you put a lot of oil on the peice you are beading and on the rollers, it makes it a lot easier.
Old Dec 17, 2006 | 02:24 PM
RC000E's Avatar
Default Re: (dave@passenger)
werrrrrrrd
Old Dec 17, 2006 | 03:12 PM
Top Ramen's Avatar
Default Re: (RC000E)
The link I posted shows it on sale right now at Eastwood for $405. That's a pretty good price.
Old Dec 17, 2006 | 04:03 PM
scartail's Avatar
I don't know if anyone has pitch this idea...
Could a hand punch or a bench punch be used to create dimples?
Have the edges of the hole and punch rounded off, and possible use a smaller punch (i.e. hole being a bit larger than the punch). Punch a whole array of dimples, then you're good. I know it doesn't have the asthetics of an expensive roller.
I think this could be a cheap alternative for some of us home garage diy'ers.
What do you'll think?
Old Dec 17, 2006 | 04:38 PM
Bailhatch's Avatar
Default Re: (scartail)
Beadform works great for charge pipes
Modified by Bailhatch at 9:58 PM 12/18/2006
Old Dec 18, 2006 | 04:28 PM
CRMB's Avatar
OG Fabricator
Default Re: (Bailhatch)
If you plan on doing a lot of stainless with a bead form, call bead form directly and purchase the upgraded shaft option. We used ours daily until we bought an eagle rotary end former. It's a great little machine.
Old Dec 19, 2006 | 02:48 PM
thermal's Avatar
Default Re: (Racing-Solutions)
Great topic.... nice link from eastwood!
Old Dec 19, 2006 | 07:55 PM
adictionbass's Avatar
Default Re: (thermal)
wheres the link to the guy that did it with and a/cor p/s bracket??
Old Dec 19, 2006 | 07:59 PM
siblues's Avatar
Default Re: (adictionbass)
Here it is
https://honda-tech.com/zerothread?id=1586762
Old Dec 19, 2006 | 08:28 PM
thermal's Avatar
Dang.... I think I'm gonna build one that can be hydraulically operated....
Old Dec 20, 2006 | 12:08 AM
RC000E's Avatar
That homemade setup isn't cutting it on .065 wall **** though on it's best day. That dude had to turn the pipe by hand on top of it.
I wonder about doing a few dimples around the circumference of the pipe though. Sounds like a descent idea.
Old Dec 20, 2006 | 10:00 AM
sharkytm's Avatar
We built a DIY bead-maker out of a vise grip and some welded pieces.
Basically, put a /\ on the upper jaw, and a bar in the middle of the /\ on the lower jaw. You just work it around the pipe, and it squishes the pipe enough to make a bead.
Old Feb 25, 2007 | 11:23 AM
thermal's Avatar
I went ahead and picked up an ebay bead roller. Not too bad for $120 shipped. I had to modify it tho.
1) I welded an 3/8 plate on the back side to prevent/minimize the flexibility. It wasnt stable enough to bead an 18 gauge pipe. It was flexing way to much before. No issues anymore.
2) I shitcan the rotating handle. I had a broken 1/2 to 3/8 inch adapter. It was already snapped, so I just cleaned/grinded the piece and welded it on the end. Now, I can take advantage of a ratcheting rotation than trying to turn that big *** handle.
The result:
This is an aluminized 3 inch 18 gauge pipe
Old Feb 25, 2007 | 11:42 AM
RaceCity_USA's Avatar
Banned
I needed a bead roller for the aluminum tubing I have for water lines, and the cheapest one I could find, that would do ¾” tubing, was $400! So I just made one. The female part is an old bearing race and I made the male part on a lathe. Here’s a couple of pics…
and the beads it rolled in the ¾” and 1-1/4” tubing.
Old Feb 25, 2007 | 11:47 AM
thermal's Avatar
^very nice! I wanted to make my own... same idea using a bearing piece. Have you tried using that on an 18 gauge pipe? Again, good job man!!!
Old Feb 25, 2007 | 12:39 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermal &raquo;</TD></TR><TR><TD CLASS="quote">^very nice! I wanted to make my own... same idea using a bearing piece. Have you tried using that on an 18 gauge pipe? Again, good job man!!!</TD></TR></TABLE>
Thanks!
I rolled some beads on 22ga. sheet metal, but haven't tried it on 18ga.
LordAphotic
Welding / Fabrication
Dec 9, 2007 03:01 PM
Justin Olson
11
Dec 6, 2007 07:23 PM
Fred Allen Burge
10
Feb 3, 2006 06:41 AM
RCautoworks
29
Mar 4, 2005 08:07 PM
TurboMiata
25
Sep 12, 2004 01:01 AM
