B20A Idling at 3000 Rpms. Need Some Pro Advice.!!!
Old Dec 16, 2006 | 09:16 PM
elecgenius's Avatar
Default B20A Idling at 3000 Rpms. Need Some Pro Advice.!!!
i have this problem with my 89 lude b20a SI. the car stays at 3000 rpms when ever i try to haul ***. when i stop hauling ***, the rpms wont go down. i already checked the vaccumm by the diaphram and thats not it. i also checked the acc cable and it has plenty slack. it gives me codes 8,9/12/17/14. that was after i was messing with it a little but when the check engine light came on when the rpms stay stuck, it gives me the code for the egr and for the speed sensor. on my car, the sensor is just the speedo cable going to the speed sensor which is mechanical not electric. i replaced that (even though it shouldnt even affect anything) and the egr and it stills gives me those codes when the cars rpms are stuck at 3500. the car runs great, and i just checked the timing. sometimes when its really high, i restric the air by forcing the throttle hard to close a bit and the car comes to normal idle so my guess is, there is a sensor which gives it extra air when it shouldnt when the car heats up? there is a sensor by the tps that is a long cylynder vertically. there is another horizontal on the intake manifold between the manifold and head. they both look alike and from my understanding (dont know much about ludes, more of a 1.6 guy) i think its the iacv.. i replaced the one thats horizontal. please guys, i need to get this fix cus the guy at the smog place wont fix it, im tired of it revving up, and no one will buy it like that. thanks in advance. im trying to get this fixed by early sunday.
Old Dec 16, 2006 | 09:25 PM
Chain Driven's Avatar
Default Re: B20A Idling at 3000 Rpms. Need Some Pro Advice.!!! (elecgenius)
fast idle valve
Old Dec 16, 2006 | 09:47 PM
elecgenius's Avatar
Default Re: B20A Idling at 3000 Rpms. Need Some Pro Advice.!!! (Chain Driven)
where is that at. thanx in advance.
Old Dec 16, 2006 | 10:29 PM
elecgenius's Avatar
fitv... duh... never mind,,, i get it. but doesnt the fitv control the cold idle instead of the warm. im having trouble when the thermostat opens up at warm temperature. isnt the iacv the one that controls the warm and the fitv the cold idle. thankx again.
Old Dec 17, 2006 | 07:29 AM
open the valve and turn the plastic screw all the way down
hondaon18's
Jul 30, 2007 04:27 PM
shownogo
Feb 4, 2005 05:53 PM
CimorelliCRX
Jan 4, 2002 11:00 AM
vteclimey
Oct 13, 2001 11:55 PM
