4x114 onto my Ek...
Which suspension fits uner the ek's that are 4x114? A guy offer 2nd gen prelude 4x114 but wil that even work? And i saw wheel spacers that go from 4x100 to 4x114? would those work. I just got a really good deal on some 4x114 itr's that i want to put on asap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda 3300 »</TD></TR><TR><TD CLASS="quote">i dont think the prelude works..</TD></TR></TABLE>
i didnt think so. i would love to do the spacers if they dont kick the wheels out to far cuz that would eb an easy task and posssibly cheapest
You can use the prelude stuff. I did some researh on it a couple years ago and theres machine work that needs to be done to the front and rear hubs to accept the bearing or custom bearings need to be sourced. if i remember right thats the main problem. other than that, its the 96 ITR setup that has to be swapped. I do not recomend using wheel spacers or anything like that as you run into offset problems. If im wrong on the prelude/accord suspension, someone please correct me.
if you're gonna be running the ITR rims i actually suggest the spacer adapters, because with the ITR rims having such a high offset (+55) the spacer will actually make them sit better, about a +35 offset, as most spacer/adapter kits are about 20mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2coupes »</TD></TR><TR><TD CLASS="quote">if you're gonna be running the ITR rims i actually suggest the spacer adapters, because with the ITR rims having such a high offset (+55) the spacer will actually make them sit better, about a +35 offset, as most spacer/adapter kits are about 20mm</TD></TR></TABLE>
My thoughts exactly. They sit so sunk in on the ek's especially. Ill have to look into those spacers when im not at work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2coupes »</TD></TR><TR><TD CLASS="quote">KICS just came out with a good kit, search them</TD></TR></TABLE>
any idea on price?
any idea on price?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6lsvtec »</TD></TR><TR><TD CLASS="quote">any idea on price?</TD></TR></TABLE>
$130 on upgradegarage.com
$130 on upgradegarage.com</TD></TR></TABLE>
I found some of their spacers on a dif site that are 15mm which would be ok. But is there any type of spacers that convert the 4x100 to 4x114? If so i didnt see them
disasiandude
Jun 3, 2008 02:23 PM
Mr.OB*GYN_Rhett
Mar 3, 2008 12:32 PM
DunnDunn
Oct 24, 2006 10:54 AM
HotWheelz
Oct 11, 2002 10:11 PM
