Brake Booster
So I have a bad booster in my 90 Si and I am trying to replace it, it seems to be a pretty straight forward swap, but I can't manage to get one of the bolts out, its the upper drivers side bolt, anyone have any tricks or tips to get this bugger out? We spent a good 2 hours trying to get to it, and no luck.
Please help!!!
Please help!!!
Just pulled one for someone at the junkyard...it was pretty easy I used a long extension and a swivil there are 4 bolts a little trick to get to but you can and then there is alos a pin with a coter(SP?) pin that connects to the brake pedal, pull out the coter pin first just so you don't forget to, I just tried to bend the it straight and then used a vice grips and pulled it out, then just slide the metal pin out and take the 4 nuts off and pull the booster out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">Just pulled one for someone at the junkyard...it was pretty easy I used a long extension and a swivil there are 4 bolts a little trick to get to but you can and then there is alos a pin with a coter(SP?) pin that connects to the brake pedal, pull out the coter pin first just so you don't forget to, I just tried to bend the it straight and then used a vice grips and pulled it out, then just slide the metal pin out and take the 4 nuts off and pull the booster out
just for you info since you ? it, its spelled cotter.
not bagging, just letting you know.
</TD></TR></TABLE>just for you info since you ? it, its spelled cotter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">
not bagging, just letting you know.</TD></TR></TABLE>
Thanks...I knew it didn't look correct
