a couple questions about my JDM front end?
Old Dec 16, 2006 | 05:24 PM
CDN Yellow ITR's Avatar
Default a couple questions about my JDM front end?
1) are the front signals and side makers suppose to be on at all times or just blink when turning
2) i didn't notice that one of my shockets for my conrners are missing where would i go about finding one of theses are getting one that would fit??
-tony
Old Dec 16, 2006 | 06:44 PM
bigislandc2's Avatar
im pretty sure only when your blinker goes on. well at least my ek and py itr are like that.
also try password for the parts they might have them
Old Dec 16, 2006 | 11:08 PM
markpaco's Avatar
Default Re: a couple questions about my JDM front end? (CDN Yellow ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDN Yellow ITR &raquo;</TD></TR><TR><TD CLASS="quote">1) are the front signals and side makers suppose to be on at all times or just blink when turning</TD></TR></TABLE>
Blink when turning. You can do whatever you want but I'd cringe if I saw the former.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDN Yellow ITR &raquo;</TD></TR><TR><TD CLASS="quote">2) i didn't notice that one of my shockets for my conrners are missing where would i go about finding one of theses are getting one that would fit??</TD></TR></TABLE>
IIRC they should be similar to the ones in the bumper lenses on a USDM DC or corner lamps on a EG. You can use a 3-wire (parking, signal, ground) socket and just wire it to go on when signaling.
Old Dec 17, 2006 | 07:40 PM
94rs-turbo's Avatar
yeah the jdm sides markers and blinkers are suppose to be off till you use the blinker but you can wire it any way u want
Old Dec 18, 2006 | 01:54 AM
DjMigs's Avatar
the real ? is do you want them to be on all time then blink when signal is used ...
or
do you want it off then blink when signal is activated ...
i had my Da on at all times...its up to ya
also as mention above if you want a clean oem look then get a harness from passwordjdm if not you can make it work
easyFOsheezy
Mar 23, 2007 09:19 AM
dragonfly2k3
Feb 7, 2007 08:21 AM
SpoogenJay
Jan 29, 2006 12:22 PM
Ditdogs
Jun 7, 2004 01:48 PM
chuckus
Feb 28, 2004 07:28 AM
