Fuse box smoking
Old Dec 16, 2006 | 04:29 PM
96SIR's Avatar
Default Fuse box smoking
After a whole day of constant rain i tried to start my car up and it just ticks....theres also smoke comming from the underhood fuse box?!?!?...i'm guessing my fuse box got wet....has this ever happen to anyone?
Old Dec 16, 2006 | 04:57 PM
skingfreak's Avatar
Default Re: Fuse box smoking (96SIR)
was it smoke, or was it steam? either way probably not the best thing
Old Dec 16, 2006 | 05:21 PM
96SIR's Avatar
Default Re: Fuse box smoking (skingfreak)
smoke.....smelt like something burnt
Old Dec 19, 2006 | 02:50 AM
skingfreak's Avatar
i would say you have a loose wire somewhere that water might have bridged in some way? im only speculating here.
Old Dec 19, 2006 | 07:56 AM
96SIR's Avatar
Ok i checked out what was going....there was a wire exposed i guess it grounded with the body of the car,made a spark and burnt a couple wires on the fuse box harness so I joined the wires back color cordinate. When i jump start the car it starts up fine but once you remove the jumper cable the car dies. I also changed the alternator and it does the same thing. All fuses are fine...i'm guessing the fuse box is messed up???
Old Dec 19, 2006 | 08:12 AM
lunarone's Avatar
i like your avatar
Old Dec 19, 2006 | 04:28 PM
sony224422's Avatar
Default Re: Fuse box smoking (lunarone)
check your battery to make sure its ok.
Also what happens if you try to crank it without it being jumped?
Crocky
Apr 19, 2017 11:03 AM
Garebears
Mar 3, 2015 06:10 PM
VanDuzer4
Honda Civic (2001 - 2005)
Nov 7, 2013 11:45 AM
hybrid1990crx
Oct 15, 2010 04:35 PM
TorquelessB16
Jun 4, 2006 11:04 AM
