AXLES don't fit!!!!
Old Dec 16, 2006 | 03:24 PM
91dxhatch's Avatar
Default AXLES don't fit!!!!
I have a 91 hatch dx and recently had the d16A6 in it (motor died). i am swapping in a B18A1 and the axles do match up to the hubs like i had been told they would. It is getting really annoying that every little thing that could go wrong during this swap has and i finally get to were i am almost done wit it but no the dam axles dont match up. Does anyone out there know which axles i am "suppose" to use. I currently have the axles that came with the motor and tranny....... Any help would be greatly appreciated.
Old Dec 16, 2006 | 03:29 PM
white90rexsi's Avatar
Default Re: AXLES don't fit!!!! (91dxhatch)
The teg axles should fit in your dx hubs. The DX and SI hubs both work. Do the splines match up? You may need to remove your dush sheild. Are you using the intermeidate shaft that came with the b18?
Old Dec 16, 2006 | 03:30 PM
91dxhatch's Avatar
Default Re: AXLES don't fit!!!! (white90rexsi)
the splines for the teg axle wont fit into the hubs its to big
Old Dec 16, 2006 | 03:46 PM
90redintegra's Avatar
The way it sounds like you got the HF/STD hub on the car so you might need to go get another knuckle from 88-91 SI like what I did which bolts on like a charm.
Old Dec 16, 2006 | 05:34 PM
91dxhatch's Avatar
Default Re: AXLES don't fit!!!! (90redintegra)
ok that was what i was thinkin but how can i tell and if i had the d16a6 in there wouldnt that mean that i would of had to have the si hubs on there already or does the hf/std axles work wit the d16a6??? that is what is confusin the crap out of me and makin my swap a total and complete pain. plus if anyone reading this has a set of si hubs that will bolt right up and work let me know if u want to sell them. thanks
Old Dec 16, 2006 | 05:50 PM
97grnrs's Avatar
i think hf axles might work with the a6 trans so its possible thats what could have happened.. i used 90/91 integra axles and DX hubs on my 91 hatch with b18 when i did it. dx or si hubs will work.. hf wont i dont think and i know std wont .
Old Dec 17, 2006 | 06:59 AM
It's hard to track history of what has been done to the car in the last 15-16 years. So it's possible it has been changed or not. You can find out what motor was orginial in there by calling honda dealer with the vin number to get the correct model. Teg axle will not fit in hf/std hub you will need to get dx/si knuckle.
Call around the junkyard and see if you can find one from 88-91 dx/si knuckle
Good luck
Old Dec 17, 2006 | 07:16 AM
crxnj's Avatar
you sure you actually have a dx and not a std? cause alot of people confuse the two....with the a6 swap all the person had to do is re-use the std axles and it will work no problem...so yeah like these guys said get some dx or si hubs.
Old Dec 17, 2006 | 08:00 AM
91dxhatch's Avatar
Default thanks guys thats exactly what i needed to know
so i guess i do have an std then and not a dx. i was just confused with the whole d16a6 swap that was already done. i thought that they would of had switched out the hubs too but i was wrong thanks for all the help and hopefully i will be able to have my car out the garage soon. as soon as i am done wit all of the work i will start a project thread so untill then thanks for all the info and help guys.
Old Dec 17, 2006 | 08:05 AM
crxnj's Avatar
Default Re: thanks guys thats exactly what i needed to know (91dxhatch)
^do you have black and grey interior,grey vinyl seats,no passenger mirror and a black center taillight?
Old Dec 17, 2006 | 10:54 AM
91dxhatch's Avatar
Default re:
i have black and grey interior wit the grey vinyl seats but i have the passenger mirror and my back center tailight is missing.
Old Dec 17, 2006 | 01:35 PM
Contender25
Guest
Posts: n/a
The axles HAVE TO BE 90/91 acura integra 5 spd NON ABS, make SURE the intermediate shaft your using is also a 90-93 integra intermediate shaft or course.
I would also suggest popping off the dust rings behind the hubs so they fit better from what i heard and don't bind on you.
Old Dec 17, 2006 | 09:04 PM
JakeSpec's Avatar
convert to Da spindles you must have a 4 speed dx only 5 speed is a direct da axle drop in
Old Dec 17, 2006 | 11:06 PM
31flavorscivic's Avatar
Default Re: AXLES don't fit!!!! (JakeSpec)
some tool gave my SI some HF hubs during its lifetime. I was in for a nasty surprise when I went to swap the ZC axles in.
Old Dec 17, 2006 | 11:49 PM
ozrednsx's Avatar
Default Re: AXLES don't fit!!!! (31flavorscivic)
haha i had a similar problem...stupid HF's
well the weird thing was i got a swap done at whitfield on my crx HF with a b16a...so i figured they did the whole swap of knuckles and what not...BUT NOPE
so they basically got some custom axles that fit b series to those small HF hubs.
I took them out though cause i went with the siR knuckles/brakes
so if you dont want to do the hassel of swapping out knuckles/brakes blah blah i got those axels if you want to buy them
Old Dec 18, 2006 | 07:12 AM
91dxhatch's Avatar
Default Re: AXLES don't fit!!!! (ozrednsx)
so when i swap out the knuckles the rotors and brakes will be the same right? i know it sounds like a really stupid question but just asking. i have already bought new stock pads and rotors that i am hoping will fit when i change the knuckles? also to ozrednsx if i hadnt already ordered the si knuckles then i would of took those axles off of your hands
Old Dec 18, 2006 | 07:25 AM
My car is STD and I bought new rotor and pads before I knew about hub size. I just got the 91 si knuckle and my new brakes fit in there perfect no need to change anything just the knuckle. Make sure you knock out that axle sheild off the hub then you're good.
Old Dec 22, 2006 | 04:04 AM
Mike_S's Avatar
if yo uare doing a b16 obd0 swap in a 90 crx si I know you need da axles but can you use the b16 intermediate shaft??? I was told you could... Thanks Mike
soodominican
11
Jan 26, 2010 09:00 AM
hxtasy
Feb 22, 2005 06:38 AM
chrism1829
Mar 17, 2004 02:32 PM
carsaregood
Feb 5, 2002 09:05 PM
TurboMiata
Dec 6, 2001 12:36 PM
