Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
honda's factory alarm ?
Old Dec 16, 2006 | 11:11 AM
gus738's Avatar
Default honda's factory alarm ?
hey guys well i just wanted some feedback on the factory alarm for our R18's today in the morning at 4:15 am my alarm got set off for the first time ever and i was thinking that these alarms only go off when someone trys to open the car ? or for what reasons could the alarm be set off?? any feedback is aprciated thanks.
Old Dec 16, 2006 | 01:04 PM
gus738's Avatar
Default Re: honda's factory alarm ? (gus738)
wow 16 views and no replys? not even a thought?
Old Dec 16, 2006 | 01:14 PM
Nighthawk R18's Avatar
probably something u didnt know about hit your car causing it to alarm like a ball or something. could be wind also, or a car with exhaust rolled by. hasnt happened to me. only time it went off with my LX is when i unlocked the door from the outside through my window. i was like o0o i have an alarm lol.
but im pretty sure the dealer told me that there isnt any motion sensors. so i have no idea.
L-Dawg's Avatar
My first thought was "why don't you walk down and try opening it while the alarm is on?"
Old Dec 16, 2006 | 01:17 PM
gus738's Avatar
Default Re: honda's factory alarm ? (L-Dawg)
i did and its not vibration active meaning no sound system or wind or a hit on the body panel will cause it to triger nor attempting to open the handle . so it must be one of those alarms that only set off when you break a glass or somthing but i dont notice any damges on my car .....
Old Dec 16, 2006 | 04:23 PM
FBPSidan's Avatar
well the factory ones dont have any motion or shock sensors... the only way it can be set off is if the doors hood or trunk is opened while armed. They could break your window, climb in and jack all ur **** and ull never know, if you really wanna protect it you gotta go aftermarket, tomorrow ill be doing a Python 881xp with tilt sensor, shock sensor, window modules, backup siren and remote start. Will probable take all day since were gonna do it right and hide everything so far up the cars ***, lol.
Old Dec 16, 2006 | 04:28 PM
gus738's Avatar
Default Re: honda's factory alarm ? (Vegas06Si)
wouldnt an aftermarket product affect factory? so then if factory is a pos what does it protect while its set ,
Old Dec 16, 2006 | 07:03 PM
FBPSidan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt an aftermarket product affect factory? so then if factory is a pos what does it protect while its set , </TD></TR></TABLE>
aftermarket alarms &gt; factory alarms.. they have more sensors to protect you... factory alarm simply goes off if door is open while armed.. thats it. with aftermarket you can get a tilt sensor so if someone tries to jack ur car up to steal ur wheels it will go off, has shock sensor if someone hits the car, you can get a motion sensor, you can get all sorts of sensors, and it locks/unlocks ur door so you dont even need ur keyfob for that anymore.
Old Dec 16, 2006 | 08:56 PM
gus738's Avatar
so i wont need my key or what? and yes i know aftermarket alarms have certain things but i didnt knew factory alarms just triger when alarm is set and someone opens.... surely it must have someting else??? and this isnt my case because i mean what could of set it off at 4:15 am today? car was locked so that means someone tryied to steal it but i see no attempt of even opeing my door or anything of forcing my car or any damges.... any more thoughts i apricate thanks
Old Dec 17, 2006 | 10:47 AM
mInI m3 Hondeezy's Avatar
I got my alarm from the dealer im pretty sure mines has sensors because whenever i kick my tires **** goes off.
Old Dec 17, 2006 | 11:00 AM
gus738's Avatar
Default Re: (mInI m3)
hmm so that means sound systms and such vibration wil set off your alarm huh werid how mine is ....
Old Dec 18, 2006 | 11:23 AM
modifyORdie's Avatar
Default Re: (gus738)
is the facotry alarm an optional? or are you guys talking about the keyless entry? keyless entrys will set an alarm if you lock it with and someone opens it (from the inside obviously) are you sure you just didnt roll onton the panic button?
Old Dec 19, 2006 | 07:10 AM
FBPSidan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 &raquo;</TD></TR><TR><TD CLASS="quote">so i wont need my key or what? and yes i know aftermarket alarms have certain things but i didnt knew factory alarms just triger when alarm is set and someone opens.... surely it must have someting else??? and this isnt my case because i mean what could of set it off at 4:15 am today? car was locked so that means someone tryied to steal it but i see no attempt of even opeing my door or anything of forcing my car or any damges.... any more thoughts i apricate thanks</TD></TR></TABLE>
You still need ur key to turn the car on/off, just wont need to press lock/unlock on the fob. Audio systems / exhausts can set off an aftermarket alarm if the shock sensor is too sensitive, in that case, turn it down a little.
Old Dec 19, 2006 | 10:53 AM
gus738's Avatar
Default Re: (modifyORdie)
no im quite sure i didnt press the panic button as i put my keys on the wall my alarm is werid sometimes it doesnt beep when i put it to lock and sometimes it does and when it doesnt the red light doesnt flash while when it is armaed it flashes
Old Dec 19, 2006 | 07:55 PM
First off u got to make sure your doors are fully closed if not your alarm wont turn on.
Old Dec 19, 2006 | 09:26 PM
gus738's Avatar
yep doors shut all way all windows up including sunroof trunk shut as well heck even hood , does this consider a visit for the stealership?
Wazup
Audio / Security / Video
Nov 16, 2009 11:47 AM
iCollectStraws
Jul 7, 2009 12:28 AM
seer_claw
11
Mar 1, 2004 02:45 PM
drsues02
May 17, 2002 10:06 PM
B2FiNiTY
Apr 11, 2002 07:35 PM
