help with swap
Old Dec 16, 2006 | 10:34 AM
HaNsElBaDaSs's Avatar
Default help with swap
i swapped my engine becuase my old one blew up. everything is in and i thought everything was hooked up but there might be something somewhere... but there is no fuel no spark. i swapped a f22b2 usdm engine to a f22b jdm engine. the b2 is non vtec the b is vtec. both are sohc 2.2l engines. and i dont know why it wont work. the fuel should work anyway because that has nothing to do with the engine but the spark i could see it.
Old Dec 20, 2006 | 09:32 PM
Default Re: help with swap (HaNsElBaDaSs)
thanks for all the input guys i have a ligit post and noone helps me but oh my car wont start... oh that is right i need a key you are all over taht one like white on rice. everyone here talks about the h22 swap and how cool your car is. well taht is awesome htat someone wants to see how awesome thier car looks with a new grill and a cold air intake. welll congrats honda-tech is officially the worst forum. noone helps.
Old Dec 20, 2006 | 09:47 PM
mtnwkr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HaNsElBaDaSs &raquo;</TD></TR><TR><TD CLASS="quote">i swapped my engine becuase my old one blew up. everything is in and i thought everything was hooked up but there might be something somewhere... but there is no fuel no spark. i swapped a f22b2 usdm engine to a f22b jdm engine. the b2 is non vtec the b is vtec. both are sohc 2.2l engines. and i dont know why it wont work. the fuel should work anyway because that has nothing to do with the engine but the spark i could see it.</TD></TR></TABLE>
Your post was a statement of fact. I see no questions, and no question marks.
Old Jan 1, 2007 | 11:01 PM
Default Re: help with swap (mtnwkr)
here sorry does any1 have any idea on what the hell it could be?
Old Jan 2, 2007 | 06:39 AM
turboH22Aakkord's Avatar
ummm im not an expert on f22 swaps or anything, but do they require a different ecu? i would double check alllll your grounds and wiring connections... one engine might have had an internal coil or an external one ... like i said, im no expert, i just thought i would toss you some ideas...
Old Jan 2, 2007 | 07:28 AM
92accordh22a's Avatar
Default Re: help with swap (turboH22Aakkord)
im pretty sure the dizzy's are different just because youtr using the one that came with the motor does not mean its not diff. @ the plugs. u could use the same ecu you have been but vtec won't kick so its not your ecu, like the other guy said make sure you have all the plugs in the right place and all your grounds are hooked up ,
might also be bad dizzy and bad fuel pump but i don't thinks so BUT COULD BE!
before you start buy new parts check all your wiring.
Old Jan 4, 2007 | 12:46 AM
TOP END MS's Avatar
Theres very little info to go by. The engine needs air, fuel and spark .. and your saying you dont have fuel or spark and you want us to guess why. Well truth is there is 500000000000000 reasons it could be based on the description.
Jeremy Thomas
Jan 1, 2019 10:46 AM
Aar0n
Nov 29, 2014 02:02 AM
Fugeeu
24
Aug 13, 2004 01:38 PM
DELGAJS3
Jan 15, 2004 07:49 PM
Stinkycheezmonky
10
Jan 15, 2004 11:29 AM
