Painting the side moldings..
Old Dec 16, 2006 | 09:43 AM
nukedawhales's Avatar
Default Painting the side moldings..
i'm to cheap and i'm going to do diy painting the side moldings on my car. My color of my car is milano red, and i have black moldings should i wet sand it first and than paint it red or can i just paint over them.
Old Dec 16, 2006 | 10:07 AM
Jonknee's Avatar
Default Re: Painting the side moldings.. (nukedawhales)
Sand it first, be sure to clean them good, thinner or w/e. and paint.
Old Dec 16, 2006 | 10:21 AM
bmoua's Avatar
Default Re: Painting the side moldings.. (La-Quiete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La-Quiete &raquo;</TD></TR><TR><TD CLASS="quote">Sand it first, be sure to clean them good, thinner or w/e. and paint.</TD></TR></TABLE>
i did my on my EJ8...sand it down good, then primer, paint, and then alot of clear coat...o and if you want to do it quick a blow dryer helps...
Modified by bmoua at 11:33 AM 12/16/2006
Old Dec 16, 2006 | 10:26 AM
good info, thank guys.
Old Dec 16, 2006 | 12:15 PM
vtec4lyfe's Avatar
Default Re: (nukedawhales)
First of all rushing the time the paint takes to dry is not recomended becasue your will only be drying the surface layer and nothing gets done right in a rush!
Now second use a fine grit sand paper and lightly scuff up the molding so the paint will adhere to the surfece better. Now use a degreaser to remove all contaminents and particles that would ruine your paint job. If possible use a type of plastic primer but if not go ahead and do several light coats untily you are happy with the outcome. Wait an hour or so for the mouldings to dry now apply several layers of clear coat.
Hope this helped
chafetzk
Mar 31, 2011 02:54 AM
broketuner-Sol_Si
Feb 13, 2006 09:52 PM
Bonez21
Oct 17, 2004 09:57 PM
posterchild
20
May 27, 2004 03:41 PM
deeweezy
Aug 17, 2003 07:19 AM
