help on where hose goes
Old Dec 16, 2006 | 09:27 AM
lsvtechatch92's Avatar
Default help on where hose goes
im hooking up the coolant lines from the water pipe on the back of the block to manifold.... i have one neck coming off the pipe that goes to the iacv (idle air control valve) from the iacv i have a neck that comes out... and goes to throttlebodie...and the throttle bodie has a neck coming out the front...where does this go... doesnt it return back into the cooling system... im not sure...can i just block it off or what all help is apprecitated
Old Dec 16, 2006 | 09:49 AM
boostin92hatch's Avatar
marcus y r u doing it thats way>>? if i was u i would T in to the throttle body for a feed and then but the drain in that bolt on the front of the block. just take the bolt out and tap it. need any help let me know
jamesfawcett
Sep 22, 2010 12:52 AM
Mark96Ex
Nov 29, 2008 12:50 PM
xlasianizelx
Mar 13, 2008 09:41 PM
B18 CYA
Aug 29, 2006 06:48 AM
ARACER25
Oct 13, 2002 10:41 AM
