Car will not start
There was a kill switch in my car for the fuel pump and i think the wires may have touched and now my car will not start.I have a solid CEL and the car turns over but the fuel pump isnt coming on.Any help?
Check the fuse for the pump first. Then check and see if the pump was fried. (Apply 12v and ground the pump.) Get rid of the switch if you want. (at least fuse it)
Pull the code for the CEL. That should be a good start. Good luck!
