help me
guys I know this is stupid, I just got a ticket because of my brake light. I just want to ask if you can show me a diagram of how to replace a brake light of 1993 civic HB. I have a light on the top of my spoiler but none in the rear lights. which is the brake light, is it in the trunk or inside the compartment in the body. help me pls.
it is the lower outer lights. so open your hatch and remove the panel inside (not the one on the hatch). and twist the lower plug thingy. i forget the bulb size but the auto store they will look it up for you. the bulb has 2 little nipples on it to hold it in place and they have to be on the correct side for it to fit so if it doesnt fit one way try the other. then just twist it in. its not that hard. your manual should tell you how if you need more help.
good luck
good luck
newyawkballa
Aug 8, 2011 06:55 PM
TealCivic93
Aug 30, 2005 01:18 AM
