burned 2 starters what can cause this problem?
i got a 90 civic sedan and i recently changed the main relay cause the car wouldn't start. now the problem is the car keeps killing the starter. it'll turn on several times fine and after it won't crank over. also yesterday the car shut off while i was driving the battery got really low and it died (battery is new got it 4 days ago) i need help a.s.a.p cause i got the car stuck at walmart
check the wiring on your alternator, f its crossed you will have all kinds of problems, like blowing your main relay and frying all kinds of ****.
check the ground on your starter also, follow the wire all the way, see if its touching anywhere etc...etc....
mostly check the grounds....intake, tranny, head, block......but mostly the wiring around the alternator and the starter.....look at the connections and wires on the battery too....check for corrosion and faulty connections at the brain
