Car dies wile driving, searched
D15 engine, will stall while driving and not restart by releasing clutch. When I pull over, I have to crank and crank before it will restart and sometimes it won't even turn over. Could this be a bad main relay? I am getting a code 3 also. This started happening gradually and now it is to the point it won't stay running for 5 minutes. Also when it warms up, idle drops to around 200 RPM. Please help!
Modified by wood 1 at 7:43 AM 12/16/2006
^Wow same thing happened to me last night(check my post) but I have a automatic d15. Last time it happen the distributor was shot, replaced that and it ran fine until last night. Although I don't know the problem its crazy the same problems are happening to these engines.
if you have fuel and spark check your distributer roter allen key bolt. mine came out a while ago and my friends just did the same thing i though it was the main realy but then i replaced it and the same thing happend it was lame
hope that helps
xd-rockx
hope that helps
xd-rockx
map sensor signal is bad! either sensor went out! the plug to the sensor is corroded or the ecu pinouts are corroded check the C plug on the ecu harness or go to http://tech.hybridgarage.com/tech/index.html check ecu pinouts for map sensor and make sure its making a good conection had the same prob on a homies DA it was just a bad plug and we re sodered a new one on! problem was gone
my problem turned out to be a bad coil in the distributor. I replaced it and the car once again runs like a dream!thanks to anyone who tried to help, but noone was close to the problem.
