part throttle hiccup
Old Dec 16, 2006 | 05:42 AM
dbiker207's Avatar
Default part throttle hiccup
the engine is a b16a1 with a 94 GSR head. i used crome to write a stock b16 p30 map minus o2 sensor, ELD, and knock sensor on a p28. the problem is that when driving under 25% throttle the car will just fall on its face all of a sudden then be fine. the idle also ***** up once and a while when it is warm (start bouncing to like 1500). when i take the intake tube off there is suction from the top hole when warm (i think its the iacv hole). i tried replacing the iacv with one i had but i dont know for sure it was good. my question is could the iacv create these issues or should i be looking for some other problem
Old Dec 16, 2006 | 06:39 PM
dbiker207's Avatar
Default Re: part throttle hiccup (dbiker207)
bump
Old Dec 16, 2006 | 08:54 PM
MecUneek's Avatar
just by looking at the title and scanning your explanation..
sounds like a vacuum leak... and if not you have a miss...
davenport517
13
Apr 21, 2008 11:27 AM
kootari
Feb 10, 2007 04:07 PM
fizban555
May 24, 2006 03:54 PM
98gsrTEG
Apr 17, 2004 11:12 AM
prendi
17
Apr 29, 2003 07:38 AM
