Tire not mounted properly on rim
Old Dec 16, 2006 | 05:39 AM
chahsiubow's Avatar
Default Tire not mounted properly on rim
I'll take pics of it later, but I had a set of falken ziex 512, 195/55-15 mounted on some LS mesh rims and it looks like it isn't seated properly. The tire looks like it's popping our the rim by half an inch. This normal? Or did the lube guy mess it up?
Old Dec 16, 2006 | 05:48 AM
C_H_A_D's Avatar
Default Re: Tire not mounted properly on rim (chahsiubow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chahsiubow &raquo;</TD></TR><TR><TD CLASS="quote"> This normal? Or did the lube guy mess it up?</TD></TR></TABLE> Does it look different than the other 3 tires? If yes then it is wrong.
Old Dec 16, 2006 | 06:14 AM
chahsiubow's Avatar
well, they all look like that.
Old Dec 16, 2006 | 06:31 AM
JoePSI's Avatar
Default Re: (chahsiubow)
Its most likely the wall that protects your lip. I've never had falcons but my yoko's had that. shouldnt be 1/2 in tho, maybe 1/4 inch.
It also happens when you put larger tires on smaller rims such as a 215 on a 7. but this isnt in the case of yours. 195 is fine for LS (which i think is 6)
Heres a 512 that shows what I'm talking about.
Old Dec 16, 2006 | 08:23 AM
eMpAtHy's Avatar
Default Re: (JoePSI)
if youre talking about what i think you're talking about, it should look someone like a spine ramp. its a lot smaller on ur tire obviously and its not as long. ithere is a picture of it:
falken designed this so that it sticks out more so that when you might swipe a curb, it could potentially protect ur wheels from curb marks.
Old Dec 16, 2006 | 08:30 AM
JoePSI's Avatar
Default Re: (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">if youre talking about what i think you're talking about, it should look someone like a spine ramp. its a lot smaller on ur tire obviously and its not as long. ithere is a picture of it:
falken designed this so that it sticks out more so that when you might swipe a curb, it could potentially protect ur wheels from curb marks.</TD></TR></TABLE>
thats what I'm refering too.
Old Dec 16, 2006 | 09:35 AM
vtecsi00's Avatar
the falken tire has what is called a rim protector that sticks out about a 1/4 or 1/2 to protect the lip of the wheel so that it doesn't get damaged as easily....
Old Dec 16, 2006 | 03:22 PM
dvp's Avatar
dvp
Default Re: (vtecsi00)
If they weren't seated correctly, they wouldn't hold any air.
Old Dec 18, 2006 | 06:13 AM
chahsiubow's Avatar
Cool, thanks for all the assurances. I just switched from a set of 02 civic se rims sitting on 195/60-15 to the LS's on 195/55-15, so they looked a little funny to me. I never got those tires before and put those tires on my gf's car and not mine since I drive 100 miles a day for work and I'd eat through those in half a year easily.
PinoyDelS0l
Jan 29, 2009 09:25 AM
volcom40street
Jan 28, 2006 10:00 PM
TeaAddict
Feb 22, 2005 05:53 AM
E Swift
Aug 23, 2003 08:20 PM
RedLinin247
Jun 24, 2003 04:09 PM
