Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Power locks question..
Old Dec 15, 2006 | 09:58 PM
tallicagolf's Avatar
Default Power locks question..
My girlfriend is planning on purchasing a base model 2004 civic. The issue is that it doesn't have power locks and she insists on having them, so my question is whats the best option? Would all the compononets from the keyless entry and power lock system from a higher model fit directly into this one? Or would she just be better off purchasing aftermarket power locks for the car? I was thinking the first option since it would be all oem components and probally turn out to be a cleaner fit. Any one have any insight on this? Thanks
Old Dec 15, 2006 | 10:22 PM
Miracle's Avatar
Default Re: Power locks question.. (tallicagolf)
It will all bolt in directly... as long as you get all OEM parts... it's not hard to install it all.
Stay with OEM, fit and finish, as well as being covered under the factory warranty.
Go here for all your parts: http://www.hondaautomotiveparts.com or http://www.hondapartsdeals.com
Old Dec 16, 2006 | 05:07 AM
toyomatt84's Avatar
Sanji
I did the HandA Accessories install, which came with instructions, and it was VERY easy to do. You'll need to get the Stereo's CODE before un-hooking the battery. Otherwise, she won't have a stereo when you re-connect the battery.
Old Dec 16, 2006 | 01:52 PM
Default Re: Power locks question.. (Miracle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle &raquo;</TD></TR><TR><TD CLASS="quote">It will all bolt in directly... as long as you get all OEM parts... it's not hard to install it all.
Go here for all your parts: http://www.hondaautomotiveparts.com or http://www.hondapartsdeals.com</TD></TR></TABLE>
Thanks for the websites. Im still not sure exactly what I need regarding the parts, I checked out the first website and it had all the parts for the automatic door locks but I don't know which parts are needed for the install. I found a keyless entry + attachment kit under accesories, but Im not sure if this is what Im looking for heres the link its the third item from the bottom. It would be great if somone can tell me all the parts I need for the install. https://www.hondapartsdeals.co...XEL01
Old Dec 17, 2006 | 04:23 PM
Anyone?
Old Dec 17, 2006 | 04:57 PM
LowTec MOHawk's Avatar
im pretty sure its not possible to add power locks and/or windows because theres no harness from the fuse box as well as the fuse box is different (according to part numbers). even if it is its gonna cost an arm and a leg with all the cost in actuators, switches, wiring and fuse box. i dunno if some one has done it id like to know how(with out using aftermarket that is)
Old Dec 18, 2006 | 02:36 PM
Default Re: Power locks question.. (mikeformos03dx)
Well im just want to add power locks not windows. From what other people have said it sounds like it has been done. It would be great if someone can list the parts involved in the instalation or a whole kit or somthing.
Old Dec 18, 2006 | 10:37 PM
well theres plenty of aftermarket power lock actuators..........you can get a "karr" alarm and get a second actuator for the passanger and youll have power door locks
Old Dec 18, 2006 | 10:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeformos03dx &raquo;</TD></TR><TR><TD CLASS="quote">well theres plenty of aftermarket power lock actuators..........you can get a "karr" alarm and get a second actuator for the passanger and youll have power door locks</TD></TR></TABLE>
I realize that its just that I would prefer an oem look and all with honda parts.
Old Dec 18, 2006 | 10:46 PM
ohhh then theres no way without spending bookoo $$$$$$$
Old Dec 18, 2006 | 11:18 PM
PnX-R's Avatar
If you're planning on buying that 04 Civic, you'd better find a way to install the OEM parts.. As to whether or not you can install them, I'm not sure, I think harness are different. All I can tell you is that if you install an aftermarket set, be ready to diagnose it yourself when you have door lock problems.. The dealer won't even touch it if it's aftermarket..
Old Dec 19, 2006 | 01:38 PM
Default Re: Power locks question.. (PnX-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnX-R &raquo;</TD></TR><TR><TD CLASS="quote">If you're planning on buying that 04 Civic, you'd better find a way to install the OEM parts.. As to whether or not you can install them, I'm not sure, I think harness are different. All I can tell you is that if you install an aftermarket set, be ready to diagnose it yourself when you have door lock problems.. The dealer won't even touch it if it's aftermarket..</TD></TR></TABLE>
Ive concluded that going the oem route would be the cleanest and best fitting, but it seems like its going to cost an arm and a leg to do it right. So ive decided that going aftermarket is my only choice. I know I need the actual aftermarket alarm kit and some actuators for the doors, is there anything else or is it that it?
bspeed
Engine Management and Tuning
16
Jul 14, 2015 11:22 PM
DrSelzer
Apr 21, 2006 07:00 AM
xci_ed6
Apr 10, 2006 08:33 AM
KrispyKreme
Audio / Security / Video
Nov 6, 2004 10:06 AM
fOmaNPu
14
May 28, 2003 09:20 PM
