ctr motor cam problem help
Old Dec 15, 2006 | 04:54 PM
B16B_coupe's Avatar
HRD PKR
Default ctr motor cam problem help
this is a friends motor.. a b16b motor complete .. after market intake mani..
adjustable cam gears
well the problem his when the crank is top dead center and we put the cam gears on to put in time the intake cam is off by a tooth when both cam gears are at top dead center as well.. we arent sure as to why it is off... even is like that with stock cam gears.. please help thanks
iam really confused right now.. so i might of typed this up prob. thanks
Old Dec 15, 2006 | 05:15 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: ctr motor cam problem help (B16B_coupe)
right size T-belt??
Old Dec 16, 2006 | 11:12 AM
2CAMSAM's Avatar
Intake cam is from 1st gen B16a(probably)-those motors had rough cast,rounded spray bars w/the TDC locating holes off center(intake toward back of car,exhaust toward front)and the locating holes in the cam(s)are not at 12 0'clock either(intake 2 o'clock,exhaust cam 10 o'clock maybe)Your spray bars should be flatter w/sharper edges and smoothly machined silver w/the holes centered in the bars.If that looks like the case to time it just use a 14 mm socket to hold true TDC on intake cam(using TDC on gear) while using the ol' phillips #2 screwdriver trick to hold the ex.cam at at at TDC.Then find out who has your CTR intake cam-the strongest oem B series In.cam,coincidently?
Old Dec 17, 2006 | 10:58 AM
B16B_coupe's Avatar
HRD PKR
Default Re: ctr motor cam problem help (92jdmcivicvx)
ok well the timing problem i fixed.. and now there is another problem. the kids car acts like it has a rev limiter and is reving really fast between 1400-1500.. weird
Old Dec 17, 2006 | 11:02 AM
POE's Avatar
POE
that sounds like a vacume issue..
Rev limitor doesnt do that.
Old Dec 17, 2006 | 11:05 AM
B16B_coupe's Avatar
HRD PKR
Default Re: ctr motor cam problem help (POE)
yeah... the kid pretty much has his motor all jacked up.. and i didnt install all the junk so it sucks worse to figure out the problem
Old Dec 17, 2006 | 11:06 AM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">yeah... the kid pretty much has his motor all jacked up.. and i didnt install all the junk so it sucks worse to figure out the problem</TD></TR></TABLE>
Welcome to kids ghetto riggin there honda's
FAST AND ORRRRR FURIOUS!
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">
FAST AND ORRRRR FURIOUS!</TD></TR></TABLE>
lol yeah.. putting turbo manifolds on a stock ctr.. ways to ruin ur car.. lol
Old Dec 17, 2006 | 11:08 AM
POE's Avatar
POE
but for real. google or search what the rev limitor is.. cause thats not what the car is doing. with what u described. and tell him to look for loose vacume hoses.
Does it idle wierd just at cold, or also at normal operating temp?
Old Dec 17, 2006 | 11:11 AM
B16B_coupe's Avatar
HRD PKR
i know it is not a rev limiter but the car acts like it has one at 1500 bouching really fast. thats what it idles at like a rev limiter... cold and warm
Old Dec 17, 2006 | 11:17 AM
POE's Avatar
POE
ok its got a vacume leak.
Old Dec 17, 2006 | 12:09 PM
B16B_coupe's Avatar
HRD PKR
he is running that big victor x manifold.. and a hondata gasket.. i thought the gasket was white? his is blue?
Old Dec 17, 2006 | 12:37 PM
SkankyEJ7's Avatar
vaccum leak
Old Dec 17, 2006 | 02:48 PM
B16B_coupe's Avatar
HRD PKR
Default Re: ctr motor cam problem help (SkankyEJ7)
yeah thats what i though.. but they said everything was good.. so ill just have to check myself.. or could it be the fitv
Old Dec 19, 2006 | 08:40 AM
2CAMSAM's Avatar
Try bleeding the coolant system THOROUGHLY-Air in coolant system,FITV(which OBD2 TB doesn't have)and vacuum leaks are ALL common causes of "bouncing Honda idle syndrome"!
AllmotorGSReg
Nov 17, 2009 12:07 AM
Old_Honda
Jan 10, 2006 09:19 AM
rough_draft
Mar 26, 2005 05:32 PM
